Old 2nd April 2009, 01:01 PM   #1
Question New LME Design -bridged / balanced inputs
I want to design a 150W amp with the LME 49830 / IRFP240 for an active speaker (SMD).
But Ive a problem to find an nice symmetrical design for such an amp for a bridged applikation which should be controlled by a balanced input.
Does anyone use the LME in inverted mode?
Ok, I could use the standard-application for each side, but I think it must be possible to use a symetrical design for a perfect performance?!
Does any user has done this before or any experience with such a design?
Thanks and regards,
Wolfram
Old 3rd April 2009, 08:50 PM   #2
qsa is offline qsa  Germany
qsa's Avatar
You should use Quasi symetrical design for mosfet amplifier with LME..., performance and sound will be excellent compare to than IRFP9240 / IRFP240.
IRFP9240 / IRFP240 looks symmetrical but they are not symmetrical. If you want symmetrical design you should use IRFP310 for IRFP240.
I had build many years before symmetrical mosfet amplifier with IRFP9240 / IRFP240 devices, performance in sound was worse...
Check schematic from Quasi member for Quasi symetrical mosfet design
Next time i will designing Quasi symmetrical mosfet design with LME
Old 3rd April 2009, 08:58 PM   #3
ostripper's Avatar
IRFP310 ?? google says it is discontinued.
Old 3rd April 2009, 11:38 PM   #4
The one and only
Nelson Pass's Avatar
The IR version of the P channel parts have a known flaw in which
the transconductance "shelves" to a lower figure in the mid-band.
This makes them even less of a match for the N channel parts, and
you want to consider that when designing with them.
Old 5th April 2009, 02:27 PM   #5
thanks for the answers. The module should be a part of a new acitve speaker electronics as shown:
In this picture is only one LME placed, so Ive to update it soon.
Here is my sheet for the first, with no values and a bit drawn "quick and dirty":
Here is the seen the beginning of the pcb-placement for this sheet:
So it will be a very tiny amplifier module, I hope
Because the SK1530/SJ201 are very difficult to buy here in Germany I want to use the IRFPs.
@Nelson:
Im having no much experience in matching FETs. Do you advice the SK1530 or to match the IRFPs?
Thanks and regards
Wolfram
Old 5th April 2009, 04:35 PM   #6
Ups, just seen that the embedded screens arent really good read ..
Here are the attached ones...
Wolfram
Balanced vs/ Umbalanced (cables, inputs, ans so on ...) teodorom Everything Else 11 18th November 2008 11:20 AM
XLR (maybe balanced) and RCA amp inputs rick57 Solid State 5 22nd November 2006 11:20 PM
balanced inputs DD_Davo Chip Amps 1 4th February 2006 04:29 PM
Balanced Inputs on Leach Amp wigginjs Solid State 18 3rd July 2004 08:38 AM
Shorting balanced inputs? dantwomey Pass Labs 10 27th April 2003 09:51 AM
Page generated in 0.09825 seconds (75.19% PHP - 24.81% MySQL) with 11 queries
