How can I wire my amplifier so I can bridge 2 channels together?
Old 1st April 2009, 11:54 AM   #1
soundengine355 is offline soundengine355  Australia
Question How can I wire my amplifier so I can bridge 2 channels together?
Hi All,
I have an Arcam FMJ P7 (7 x 150W/8 and 230W/4) amplifier which uses 2 x 1500VA transformers. I wanted to use 6 of the 7 channels to create 3 high powered channels, how would this be done?
The manufacturer says it does not support bridging, so I gather some wiring changes need to be done.
Do all I need to do is invert the signal?
Old 1st April 2009, 07:35 PM   #2
east electronics is offline east electronics  Greece
east electronics's Avatar
Default well ....it seems
that i miss something here.....
for example if your amplifier features 2x1500VA transformers would please tell us where exactly you connect this amp because from this ratings it cannot be connected to a normal socket ...
3000 VA is half the power of a coocking stove or 2/3 of a water boiler and so on .....
there is got a be something wrong here ...
then again if this is a home theater amplifier the unit is not designed for a thing like that ...
the power from amplifiers like that is way overestimated and the SOA is even worst ...
for bridging technicues you may look at esp pages
good luck ......
AndrewT once said :
"should i duck now or wait for the smoke first ?"
imagine ....andrew is a nice guy !!!!!
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 1st April 2009, 09:54 PM   #3
ostripper is offline ostripper  United States
ostripper's Avatar
Either you are filthy rich or brave...
The manufacturer says it does not support bridging, so I gather some wiring changes need to be done. [ WTF]
Don't touch it.. it is a 5000$ amp!!!!
It has 22A per channel peak power , so it does have 3kva
The only bigger PS than that is the genesis stealth with
4.4KVA
if you want more power.. build a 800$ 500w+/ch aussieamp or something.(2 1kva +-100v rails)
OS
Old 1st April 2009, 10:13 PM   #4
bear is offline bear
expert in tautology
bear's Avatar
Only amp??
Nah.
My Symphony No.1 amp is rated at 180w/ch 8ohms and uses >4kva transformers. Since 1990. Do I get a medal for being first??
Check my website.
I also used ~500,000ufd of filter cap, 1/4" solid copper buss bars and 400 amp Hexfred diodes...
Seems to work ok...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
How can I wire my amplifier so I can bridge 2 channels together?Hide this!Advertise here!
Combine 4 amplifier channels into one? thylantyr Solid State 5 4th March 2008 08:43 PM
Bridge SE amplifier croccodillo Tubes / Valves 3 17th February 2006 02:58 AM
TDA amplifier , Bridge , 600 W . darkm4n Chip Amps 0 29th March 2004 01:48 PM
how to bridge an amplifier MV Car Audio 1 25th March 2004 06:11 PM
how to connect a sub on a 2 channels amplifier Mikka Multi-Way 1 19th June 2003 11:27 AM
Copyright ©1999-2017 diyAudio
