Decibel Watts VS Watts ? - Page 2 - diyAudio
Old 1st April 2009, 11:33 AM   #11
diyAudio Member RIP
Originally posted by wakibaki
200W is 3dB (twice = 3dB) over 100W which is 20dB
(100 = 2 zeros = 20dB) over 1W.
Making a total of 23dBW. 53dBm if you like.
The impedance is irrelevant.
What planet are you on sreten?
w
Originally posted by infinia
Simply wrong dBW is the ratio of power in watts to 1 Watt
10LOG (power in watts)/1watt
Originally posted by AndrewT
Sreten was referring to dBV and got it mixed up with dBW.
100W into 8 ohms and 200W into 4 ohms are both +20dBV?
w
Meanwhile back on planet earth I understand the use of dBW's
as in the same vein as dB/W/1m for a loudspeaker. An 8 ohm
load is assumed for dBW's and it is specified effectively as the
voltage into 4 ohms, you combine this with a 4ohm speakers
senstivity in dB/(2.83V)/1m and you get the correct SPL levels.
That is how it works and amplifiers are specified.
A correctly specified 4ohm dBW value tells you the dB sag from
the 8 ohm value that weill apply if driving 4 ohm speakers that
are usually specified as dB/W/1m but in reality are dB/2.83V/1m.
/sreten.
Old 1st April 2009, 01:08 PM   #12
Banned
Sorry AndrewT, no, it seems it was, in fact, dB/W he had it mixed up with, as in the statement "100W into 8 ohms and 200W into 4 ohms are both +20dB/W".
Now it makes perfect sense.
w
ESP 60 watts Williams Audio Solid State 12 28th April 2010 12:54 PM
watts vs watts Hayden Parts 7 30th July 2006 12:57 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
SPL and Watts Matttcattt Everything Else 6 14th March 2004 10:00 PM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Copyright ©1999-2017 diyAudio
