Mcintosh Solid State Amplifier Substitute Parts
Old 29th March 2009, 10:45 PM   #1
grant_MH is offline grant_MH  United States
Default Mcintosh Solid State Amplifier Substitute Parts
Looking for a cross-reference of parts to replace the codified parts in the mac parts lists - I've seen a number of different parts suggested but the best would be to locate a cross-ref
have an MC-2105 which suddenly developed a pattern of producing lots of wide-band static and sometimes "thunder" - in fact, I discovered the problem when I thought I was hearing a thunder-storm - turned out to be the amp. One of the power transistors in the left channel was getting V E R Y hot. Figured it could be the bias resistor on the emitter of Q117
The amp is pretty easy to work on, that is disassemble and reassemble - after replacing the "bias" resistor and reassemby I noticed smoke and a popping sound - I had shorted the bias resistor against the metallic standoff - a foolish mistake which may have taken out all the xistors on the left side sitting on the -35V rail - fuses are a great invention!
any info gratefully accepted and appreciated
Grant
Old 30th March 2009, 01:05 AM   #2
llwhtt is offline llwhtt  United States
Grant,
I just finished a MC2200 with parts from McIntosh, just call them and they will tell you what the crosses are. Some of the parts are or were common. The drivers are MJ15018/19 or MJ15020/21, the outputs are MJ15003/4. The drivers came from McIntosh and the outputs came from Mouser. According to the parts department no testing, grading, or matching is done.
The parts you need are different but may be common, call McIntosh and ask. They will need the original Mc numbers though, since you know what Q117 is I assume you have the service manual. I have one if you need some info.
Craig
Old 30th March 2009, 09:25 AM   #3
Craig,
thanks a lot for the reply and the advice - I'll give mac a call to get the other cross-references. When the 2105 was working sounded great driving the ML-1s.
Do have the schematic and was able to get a xref from a local friend but it may be a pain for mac to give the subs for a lot of parts - also have a C-24 to rehabilitate.
all the best, Grant
Mcintosh Solid State Amplifier Substitute PartsHide this!Advertise here!
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 06:26 PM
Copyright ©1999-2017 diyAudio
