Hello,
I am looking for some ideas for my Carver C-2 Preamp. It has a low hum out of the right channel on all sources (loudest on MC phono Input) with the volume off and gets increasingly louder with turning up. And in both channels a buzz. I have replaced all radial capacitors with new audio grade Nichicon. And deOxiT'ed all switches and knobs. However i still get a loud pop out of both speakers when i press power switch or mute button on and off. Balance knob has no effect on the noise generated on either channel, left or right the hum & buzz is constant. All this with no other sources plugged in - just decent interconnects running to A carver Model M-0.05t that preforms flawlessly with any other preamp hooked to it. I read up on ground loop issues and tried most suggestions for additional grounding but non worked and it didn't make sense that the hum was only out of one channel and I could swap L& R channel and get hum out of other speaker. Also inspected for cold solder joints while i was replacing caps but didn't see anything that looked out of the ordinary. Please if you have any ideas I am handy with a multimeter and am ready to replace any other components you can think of even if its a longshot. Thanks in advance. |
#2 |
I will try and post in a more active thread if the moderator will allow
Thanks |
| Forté Audio Model 3: caps and schematics? | st2_998 | Pass Labs | 35 | 30th June 2011 06:21 AM |
| Sick Carver M-1.0t amp: bad caps? | sblack6 | Solid State | 1 | 7th June 2009 07:53 AM |
| Anyone have a model for Jensen 4 pole caps? | tonyptony | Parts | 0 | 30th July 2007 02:06 AM |
| Humming LW Erath Model 288 amp - filter caps (help!) | sam562 | Solid State | 7 | 12th February 2007 08:25 PM |
| Carver model M1.0T. Transformer required | andjur78 | Solid State | 17 | 24th April 2005 08:18 PM |
| Page generated in 0.07374 seconds (71.31% PHP - 28.69% MySQL) with 10 queries |
