I have an Onkyo SR806 receiver which I'm trying to fix. Looks like the left channels are out. I can find the transistors on mouser, but there's this one 3-legged metal plate resistor which I couldn't find. It says:
P H R MPR 5W R22J X2 I think it's a .68ohm x2 ceramic resistor, but I can't find it anywhere. Does anyone know where I can source these? Also, would anyone have the schematics for this receiver by any chance? Thanks and I appreciate the help! |
#2 |
P H R
MPR 5W R22J X2 equals... a dual .22R emitter resistor very common in OEMs ,a picture would confirm this. Are they these ? http://www.mcmelectronics.com/produc...5--22-/28-0540 OS |
#3 |
Yes! They looks exactly like the ones in the middle.
So R22J actually does stand for 0.22 ohms resistors in series? It's weird because when I measured with a voltmeter, it looked like it was 0.68 ohms, I need to double check. |
#4 |
DMM's aren't accurate under 1Ohm.
An 0.22Ohm resistor easly measures 0.68Ohm! |
#5 |
They're 2x0.22 ohm resistors with the centre pin common, which is where the speaker connects.
If you can't find them, you can replace with two similarly rated ordinary resistors BUT they must not be wirewound types. |
#6 |
Ah, ok. I'll place the order on the site that ostripper sent me.
Thanks a lot! |
| Need help finding a part. | Itsme | Car Audio | 5 | 27th November 2007 02:56 AM |
| Parts for Onkyo TX-V940 Receiver | rh1530 | Swap Meet | 0 | 7th October 2006 02:39 AM |
| Need help finding this part | swordfish689 | Car Audio | 3 | 5th March 2006 01:23 PM |
| Newbie needs help finding part | Safe_Cracker | Car Audio | 5 | 1st January 2006 05:57 PM |
| PSU in Onkyo TX-2000 receiver | stex | Chip Amps | 1 | 14th September 2004 07:37 PM |
| Page generated in 0.09386 seconds (74.94% PHP - 25.06% MySQL) with 10 queries |
