Old 28th March 2009, 02:49 PM   #1
paul.42 is offline paul.42  United Kingdom
Default arcam alpha 8 toroidal upgrade ?
hi all,to start with i am quiet a beginner at all this electronics stuff,i have replace toroidals in my other amps and replaced caps,but now i would like to upgrade the output in a arcam alpha 8 power amp,i have some toroidals here,but i know that vacs are alot higher ,is there away of reducing the vacs on this toroidal i have,and or what would it do??the vacs on the standard part is 25-0-25,the one i have is 80-0-80,so a big difference ?can any one there help with this..
Old 28th March 2009, 03:54 PM   #2
What exactly are you trying to accomplish? I don't wish to dampen your enthusiasm, but it's not easy to substitute a higher voltage transformer into a device designed for a lower voltage for what should be obvious reasons. In order to do that you would have to re-wind the transformer scondary windings for a lower output voltage, or add voltage regulation to the power supply. Also, the substitute transformer would have to be physically much larger to be able to deliver the necessary current at the higher voltage output, it probably won't fit inside the chassis.
Let us know what you want to achieve, then you will get better assistance.
Cheers.
Old 28th March 2009, 03:57 PM   #3
jaycee is offline jaycee  United Kingdom
It's not really feasible. You would have to unwind the toroid's secondaries to reduce the voltage. If you do this you're not going to be making full use of the core without doubling the existing secondary winding in order to carry more current.
Voltage regulation also isn't feasible. You would have too much heat from the regulator to deal with, and you would probably strangle the amplifiers power supply to the point where it would sound dreadful.
The Alpha 8 isnt the best to do this with anyway. The design of the amp is not suited to high power due to the IRF540 mosfets it uses, and the small heatsinking.
Old 28th March 2009, 05:23 PM   #4
ok so what i'm after is more klout really,so what amp is the one to go for?
Old 28th March 2009, 07:33 PM   #5
Agian, what specifically are you trying to accomplish? We need more info.
Old 30th March 2009, 11:31 AM   #6
ok,so i guess what i'd like to do is what rowemister has done to his marantz pm66 ki,look up marantz pm66 ki tweeks
so is the arcam still not the best choice of amp to up grade or should i look at marantz amps .??
Old 30th March 2009, 10:05 PM   #7
What you should do if you want more clout is buy an amp with a higher output wattage. Just adding a new transformer etc to anything is not going to get you that.
Alternatively, consider more efficient speakers.
Arcam Alpha Plus amc184 Digital Source 6 17th January 2008 06:01 PM
arcam alpha 7 amp stand Solid State 10 4th August 2007 07:27 PM
Arcam Alpha One upgrade Malefoda Solid State 39 25th July 2007 10:17 PM
Arcam alpha 9 pumpkin Solid State 0 5th October 2005 06:31 PM
Arcam alpha 6 clock upgrade tonitze Digital Source 3 17th April 2005 08:42 PM
Page generated in 0.08452 seconds (85.56% PHP - 14.44% MySQL) with 10 queries
