What's the best signal (<=1W) BJT for audio applications used as amplifier ?
Thanks Aiace |
#2 |
There is no one best of anything. There are lots and lots of good BJTs that are good in various circumstances depending on the combination of voltage, speed, gain, noise etc. you want.
Personally, I like BC550/560 for general purpose use. They have low noise and are cheap. Get ones in the 'C' gain group if you can.
https://mrevil.asvachin.eu/ |
#3 |
I agree, ... no one "best" device for input stages. One can have
a favorite based on the $$$/speed/availability ratio. For high gain/voltage 2sc1845 (npn) 2sa992 (pnp), at 1.8pF Cob 120v Vce , they fit the bill for most LTP's. Also the 2n5401 /2n5501 are great for super high rails but have higher Cob. (MPSA 92/42 are the same). The BC's Evil mentioned are very widely available and work well for lower voltage amps ( or if you use a cascoded LPT with a HV amp). Everyone seems to go for faster transistors , but sometimes this "backfires", creating the need for more care in compensation and layout to avoid oscillations. Voltage is the more important issue , as I try to derate 40% or more. ( 70v rail = 120 V device). OS |
#4 |
What I'm discussing about is the sonic performance. Certanly it depends to applcations and personal taste, but I'm sure that everyone has the own preferred one. What's one?
Aiace PS: If I had to say the trouth I'm looking for a BJT to use in an i/v converter and amplifier. I think it should have a veri good linearity of hfe over a wide range of current. Is it right? |
#5 | |
JFET inputs sound better and the japanese designers seem to agree (70% of their amps have cascoded jfet's). I have noticed that the topology and the compensation have more affect on the final sonic quality than the device used. There are truely horrible choices one can make as far as devices (a low gain device in a circuit that "needs" HG , like a non-mirrored simple LTP) but the sonics are the result of the interaction of all the stages + the feedback and compensation. The passive components are as much a factor as the silicon. If you must know MY favorite , it is the 2sc1845/2sa992- ksa992/ ksc1845, because it comes in 4 gain groups , has a very wide linear region (.01-9 ma)and is cheap($.08),quiet and fast. ( I use the "F" gain group) http://www.fairchildsemi.com/ds/KS/KSC1845.pdf http://www.fairchildsemi.com/ds/KS/KSA992.pdf original japanese 2sc/2sa's are the same.. OS |
#6 | |
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#7 | |
Re's of the LTP to the positive rail) NOT rail to rail ! (attached) For a VAS or OPS and 70v rails , yes... 250+ is the norm. I would not give advice to make those little devices "pop" like firecrackers... OS |
#8 | |
http://www.semicon.toshiba.co.jp/doc...eet_071101.pdf |
| Any of these tubes good for audio applications? | Binaural | Tubes / Valves | 14 | 25th February 2009 12:34 AM |
| Audio applications of sweep tubes and ratings | weinstro | Tubes / Valves | 8 | 29th February 2008 07:07 PM |
| Book FS: Audio IC Op-Amp Applications by Jung | davidhs | Swap Meet | 2 | 15th July 2007 03:21 PM |
| Books on electronics in audio applications: recommendations? | LowRedMoon | Parts | 3 | 5th January 2006 06:56 AM |
| Page generated in 0.09235 seconds (86.56% PHP - 13.44% MySQL) with 11 queries |
