Old 22nd March 2009, 02:30 AM   #1
unclejed613's Avatar
Default isolated high voltage amp
i have a subscription to EDN (electronic design news), and i get some of the tidbits from the magazine emailed to me before i actually get the paper one in the mail. they have audio circuits in their "design ideas" column often enough to make it worthwhile getting the magazine.
i just got this one in my email, and it looks interesting, even though it is a quasi comp.......
http://www.edn.com/article/CA6643367...36&rid=1250817
the wording about overcurrent protection isn't really clear, but i'm guessing he meant 125ma fuses on the rails. at 125ma output current and driven to 1kv, that's an 8kohm load, so as-is this circuit is "not yet ready for prime time", but it has possibilities....
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 22nd March 2009, 02:56 AM   #2
jackinnj's Avatar
Hmmm, I did quite a bit of work 4 years ago w analog opto-isolators --not the 6N36 device shown in the EDN article -- but Hewlett Packard (AVAGO) and Siemens devices -- very linear, but not particularly fast.
Old 22nd March 2009, 02:03 PM   #3
sakis is offline sakis  Greece
sakis's Avatar
Default this obviously a
very primary circuit but it looks like the best pa amplifier ever....this is probably the lowest part count for such a big amp ....
so whats the idea here unclejed ????
regardless the protection do you have anything else that troubles you ???? cause constructing a toy like that is probably 1 hour of work for testing perpus ( and i am really willing to !!!!! )
join in !!! tell us more !!!
small detail : i think that forum policy is against online circuits but at the age of 43 and after a univercity degree i consider safety a must but on the other hand rules are rules ....so in case that moderators decide to stop this i would like to continue this in private ...i try to e mail you through the forum but it doesnt work ...so you may email me any time you like .... thank you and stay in touch !!!!
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 22nd March 2009, 02:56 PM   #4
wg_ski is offline wg_ski  United States
Default Re: this obviously a
Not necessarily a *big* amp - 8k ohm load is kind of high. But it could be scaled up. This does, however, look like an interesting way to drive a pair of hexfets/bipolars/etc from 15 volt op amp supplies without having to resort to using separate power for each channel.
Old 22nd March 2009, 03:08 PM   #5
sakis's Avatar
Default true .....
that is correct but you know what i mean..... this could be adopted or scalled down to a PA application ....what do you think ????
Old 22nd March 2009, 03:09 PM   #6
jcx is offline jcx  United States
you will quickly run into slew rate problems with large input C devices - the high speed optos used can't reliably control more than 10-20 mA - and that requires device selection for higher CTR
also rail efficency is too low at the lower Vsupply of 4-8 Ohm loudspeaker power amps
Old 22nd March 2009, 03:52 PM   #7
it would take 1000 of these (paralleled) as-is to drive an 8 ohm load, but i thought it was an interesting drive method.... an optical VAS. it looks a bit tricky to bias, since that's handled by the pots in series with the LEDs.
Old 22nd March 2009, 11:26 PM   #8
You could add a nice little complementarty EF pair, biased at a few tens of mA in between the opto's output transistor and the gates of the compound FETs. That will drive an amp or more of peak gate current if you need it at high frequency.
Old 24th March 2009, 12:19 AM   #9
Great find unclejed!
I have seen this kind of amp used in some high voltage industrial amplifiers. A conceptual question:
If the output voltage is going positive, then the top half of the circuit will be supplying the current, through the source of Q2 (a common drain-type configuration). If the output voltage is going negative, then the bottom half of the circuit will be supplying the current through the drain of Q3 (a common source type configuration). Won't this create some kind of "mismatch" to the load in terms of output impedance of the amplifier?
I guess the same question could be posed about any kind of amplifier that uses a quasi-complementary output stage.
Old 24th March 2009, 03:14 AM   #10
Both sides behave as common-drain and have equal voltage gain. The signal for both FETs is injected at the gate-source junction as a voltage, and the output is a current in the drain circuit. The DC power supply changes "position", but that's zero ohms as far as signal is concerned.
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
are isolated supplies needed for high-power class-D? iand Class D 22 25th February 2009 09:46 PM
Isolated voltage feedback for SMPS rtarbell Power Supplies 2 25th July 2007 03:41 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Page generated in 0.12410 seconds (80.64% PHP - 19.36% MySQL) with 10 queries
