Old 24th March 2009, 03:26 AM   #11
unclejed613's Avatar
as far as output impedance is concerned, that is mostly determined by the feedback ratio. the actual output resistance is only a very small factor. basically the output impedance is the output resistance divided by the feedback ratio. an amplifier with feedback will correct for discrepancies introduced by output resistance, and that effectively lowers the output impedance. the power supply and output devices do place limitations on how well the amp can maintain that low output impedance (there's no such thing as a free lunch).
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 24th March 2009, 02:11 PM   #12
wg_ski is offline wg_ski  United States
Originally posted by wg_ski
Both sides behave as common-drain and have equal voltage gain.
Correction - both behave as common *source* with equal voltage gain/output impedance.
It is commonly mistaken to think of the upper unit as common drain and the lower one as common source, which would have unequal gains. But the input signals to both are in the same place - straight across Vgs. Neither signal is ground-referred, which is why you can drive staggeringly high voltages with this.
Back in The Day, we used to do this with a pair of PNP Ge's with a dual-secondary transformer. The transformer works well for driving FETs as well, and removes the speed/bandwidth limitations of an unassisted optoisolator. Speaking of which, does anyone know of a decent source for this type trafo these days (other than an old vintage amp)?
Old 24th March 2009, 03:34 PM   #13
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
I suppose you could use an amp like this to directly drive electrostatic panels without the step-up transformer?
Old 24th March 2009, 11:51 PM   #14
there ya go.... i was thinking of modifying the circuit for lower voltage/more current, but somebody spotted a use for it as-is...... cool
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 08:05 PM
are isolated supplies needed for high-power class-D? iand Class D 22 25th February 2009 09:46 PM
Isolated voltage feedback for SMPS rtarbell Power Supplies 2 25th July 2007 03:41 AM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
Page generated in 0.07290 seconds (71.29% PHP - 28.71% MySQL) with 10 queries
