Are there any Class A designs which
Old 21st March 2009, 08:29 AM   #1
454Casull is offline 454Casull  Canada
Default Are there any Class A designs which
have a very high output impedance, no or little negative feedback, and can output ~50W per channel? If not, is it possible to design such an amp?
Thanks,
Howard
Old 21st March 2009, 09:47 AM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: Are there any Class A designs which
Thanks,
Howard
Yes, just upscale an inductor loaded Zen 7.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 21st March 2009, 10:20 AM   #3
wakibaki is offline wakibaki  United Kingdom
Banned
If you call valve amp OP stage impedance 'very high' then you can take any amplifier outputting 50W into 8 ohms and give it a high output impedance by feeding it into a reversed OP tx. If it was a class A amp with little or no negative feedback that would satisfy your conditions, n'est ce pas?
w
Have you actually got one of those hand cannons?
Old 21st March 2009, 08:29 PM   #4
w
Nope. I live in Canada.
Old 21st March 2009, 09:40 PM   #5
wg_ski is offline wg_ski  United States
Thanks,
Howard
This sounds like what you want. You just need more bias and more cowbell, er, hexfet.
http://www.diyaudio.com/forums/showt...threadid=42259
Are there any Class A designs whichHide this!Advertise here!
Int. Rect. Class D reference designs stoc005 Class D 3 17th February 2007 03:51 PM
2 Designs for Class D Power Supply - Which One? bck2diy Class D 35 21st May 2006 11:37 AM
Quality of filter caps in class A or AB designs. beppe61 Parts 7 9th February 2006 07:19 PM
Class B designs with high fidelity? Joel Tubes / Valves 30 7th July 2003 09:35 AM
Why do so few designs use opamps working in class A? fmak Solid State 19 23rd May 2002 03:25 AM
