Hi i just joined this forum in the hope that some one can help me with this amp its a C-audio RA3001 protection light is on and the two -20dB leds are also on. No fuses blow and there is no dc (5mv) at the output of the transistors. does anyone have the schematic or any advice Please.
No Thanks Cisco,
I had help from another contributor to this Forum.
It helped me to.
Glad to hear it whas a minor problem.
These are usually hard to find and without a ttrasure map (schematic) it can take ages...
Even if the amp is a simple cheap model or an expensive and complicated one.
A schematic can guide you through the jungle of pcb tracks, dangling wires and frightful electronic parts.
Oeps, my many years in the jungle is getting through...
Tarzan
It helped me to.
Tarzan
