Old 17th March 2009, 11:59 PM   #1
rtate is offline rtate  Canada
Default P.S. question...
Are there any disadvantages in using 1 PS cap inplace of 2??
I have an Adcom GFA-555 with old caps and I am not having much luck finding replacements at the same or slightly higher value.
Each channel uses 2 15,000uf caps rated at 80v.
I have 2 33,000uf 100v caps that I could use but I thought I read somewhere that it is better to use multiple caps for the power supply.
Opinions??
Old 18th March 2009, 12:36 AM   #2
Banned
rtate,
the outcome chiefly depends on their quality
Old 18th March 2009, 12:42 AM   #3
all things being equal quality of coarse...
Old 18th March 2009, 12:47 AM   #4
Ragnwald's Avatar
This amp has two powersupplys sharing one transformer.
Each supply neads at least two caps, one for + and one for - rail.
Old 18th March 2009, 03:38 AM   #5
lgreen is offline lgreen  United States
lgreen's Avatar
Default need 2
It depends on how they are connected. If in parallel it likely won't matter. Here though they are not, so you need 2 caps, one for the + supply and one for the - supply. Yours are bigger and should work.
Multiple caps are preferred because if you put multiple caps in parallel they have lower ESR (resistance) than a single cap, but that is beyond what you are dealing with here.
My DIY audio projects- PartTimeProjects.com.
Old 18th March 2009, 03:50 AM   #6
Banned
tate,
Of course...
Old 18th March 2009, 10:54 AM   #7
sorry if I wasn't clear enough...
There are 2 caps connected in parallel for each channel...
2 x15000uf for 30,000uf per channel.
I would like to use one-- 33,000uf cap for each channel...
Is there a problem with this??
Old 18th March 2009, 11:34 AM   #8
Ragnwald's Avatar
Scroll to the bottom of the
schematic .
Old 18th March 2009, 11:40 AM   #9
AndrewT is online now AndrewT  Scotland
the PDF schematic clearly shows +-15mF 100V on each channel.
Is your's the same?
regards Andrew T.
Old 18th March 2009, 02:21 PM   #10
Mine is not the MK-II however it is the same configuration..
I have now seen the light
Please excuse my ignorance....
I now see that I do need 2 pieces for each channel...
Now if I could only find some suitable replacements that don't cost as much as I paid for the amp...
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10769 seconds (79.65% PHP - 20.35% MySQL) with 10 queries
