Old 17th March 2009, 12:24 PM   #1
xcicc is offline xcicc  Italy
xcicc's Avatar
Default ampli mosfet irf 540 + irf9540
I found this project on the internet I tried to build it but does not work, on the mosfet gate drain and source, there 'always 22v
the power supply is a toroidal 15 + 15v
any suggestion?
thanks
Old 17th March 2009, 12:47 PM   #2
acid_k2 is offline acid_k2  Italy
-wich mosfet?
-first step, as always: check power supply, wiring and shorted pins.
Old 17th March 2009, 12:52 PM   #3
Corax is offline Corax  Germany
The schematic doesn't seem to be wrong.
And concerning the voltages you mentioned on Gate, Drain and Source of 22V, I guess you mean T5 (IRF540).
For any further 'guesses' it would be nice to see your PCB layout (if there's one at all).
If nothing is blown yet, nothing is getting real hot and no fuse is blown, I still believe the fault is either a missing connection or even a wrong connected transistor. What's by the way the voltage drop between Collector and Emitter of T3 (BC238: the BIAS setting transistor) and what's the voltage level at the sources of the MOSFETs? What is the idle current consumption of the amplifier? What happens if you turn P1 with it's slider slowly in direction to R12, which will/should increase the idle current through the MOSFETs (ATTENTION: stop turning P1 when you reach or exceed a current of 100mA and turn it back if necessary). Since no small Source resistors (i.e. 0.33 ohm) are available you can measure the current of the whole amplifier in the positive rail.
Post your readings and picture(s) and we'll see.
Old 17th March 2009, 01:05 PM   #4
mjf is offline mjf  Austria
hello.
perhaps d1 or t5 built in wrong or damaged...........
greetings..............
Old 17th March 2009, 01:08 PM   #5
xcicc's Avatar
Originally posted by acid_k2
-wich mosfet?
Hi, the mosfet are IRF540 and IRF9540
I checked many time the power supply... and above all its very easy and simple....
thanks
Old 17th March 2009, 01:15 PM   #6
xcicc's Avatar
Originally posted by Corax
[B]The schematic doesn't seem to be wrong.
also for me doesn't seem wrong.
I meen 22v on gate drain and source on IRF540 and IRF9540
yes now post only from my pc after the real photo (give a few minute...)
the primary of the transformer I connected a 65W light bulb from 220v to protect. there is a problem if the bulb comes on.
by adjusting the trimmer does not change anything
in almost every measure of the circuit from 21 to + / - 22v
is incredible .... would not believe ...
Old 17th March 2009, 01:18 PM   #7
xcicc's Avatar
Originally posted by mjf
hello.
I have already checked and changed the final more than once ...
beginning to be tired of this simple but that does not work ... seems to take the game to me
Old 17th March 2009, 01:32 PM   #8
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
search for Papa's Citation 12
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 17th March 2009, 01:35 PM   #9
BV is offline BV  Slovakia
Change R5 to 820R or 1k( or change R3 to 8.2k or 10k). This schematic needs (to work correct) supply voltage about +-35V.
Old 17th March 2009, 01:38 PM   #10
xcicc's Avatar
some picture...
my new ampli mosfet xcicc Solid State 23 12th August 2008 02:44 PM
ampli mosfet with irf530/9530 ciccio9000 Solid State 17 10th June 2007 10:41 PM
irf540 and irf9540 can these be tested with a dmm homertooties Parts 8 13th November 2006 10:36 AM
irf9540 mosfet test(p-channel) luv2bass Parts 1 2nd February 2004 09:35 PM
Page generated in 0.10270 seconds (77.62% PHP - 22.38% MySQL) with 11 queries
