Old 11th May 2009, 02:39 PM   #41
wg_ski is offline wg_ski  United States
Originally posted by nigelwright7557
I now use +/-60V and that seems to be a lot better.
Sadly the price of electrolytics rockets above 63V.
Amplifier power rockets above 63V, too. And amp rails are never as stiff as you expect them to be based on trafo regulation specs.
Old 11th May 2009, 03:35 PM   #42
tinitus is offline tinitus  Europe
LarsClausen(LCAudio) once showed how to use seperate standard +/- supply fore each half of the balanced/bridged amp, using smaller voltage caps
But ending with a single higher voltage cap across + to -
Ground would be sort of floating
Old 11th May 2009, 03:57 PM   #43
nigelwright7557's Avatar
Thats becasue the output power is V squared/ speaker impedance.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software.
Old 11th May 2009, 04:40 PM   #44
destroyer X's Avatar
Default Why are you needing all that power Satji?
Do you have speaker enougth to all that power?
Will be some special application, alike football field or enormous open air alive performance or something in a such direction?
Man!.... this heatsink cannot hold all that power.
I feel curious....just that.... i have some speaker here, used into automobile, so bad they are(low efficiency) that needs 400 watts RMS to move..is this your case?
Carlos
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0
Old 11th May 2009, 05:05 PM   #45
Default I understand that some applications needs power.
I am very curious about yours....please, let me know.
regards,
Carlos
http://www.youtube.com/watch?v=2SBEJffbwHk
Old 11th May 2009, 07:30 PM   #46
sajti is offline sajti  Hungary
I want to use it for 2 different application:
- home system to drive my 8ohms Focal loudspeaker, mainly in class A, up to 100W.
- to drive the front, and subwoofer in a party (my subwoofer contains 2x18" Beyma loudspeakers, and can handle 1800W rms)
I know that this heatsink is not enough. This is for test only. I'm not sure the final solution. I have two possibilities:
1, 40cm long heatsink for each module
2, keep this heatsink, and use forced cooling with variable speed fan
Sajti
Old 26th August 2009, 08:01 AM   #47
I had no time in the last few weeks, but now I start to do some measurements, and try some other solution.
So, the prototype contains now: 4pairs of MJL21193/94, and NJW0281/0302 as drivers and no predriver. I measured the input impedance, which is 12kohms, with 2ohm load (it means 4ohm nominal load for the bridged amplifier). It's not so hard load, and I can drive it with White follower using ECC99 (150V/18mA anode current). I still working to put it together...
Sajti
Old 26th August 2009, 08:33 AM   #48
Zin=12k with 2r0 load.
Zin>4k with 2ohm reactive load?
What about Zin dips when abuse occurs?
Old 26th August 2009, 08:38 AM   #49
The driver tube can drives 1kohm load with full output swing (60Vpp), so some impedance drop can not be problem. If I use all the output devices (8pairs), there will be no B drop even with 2ohm balanced load.
Sajti
Old 26th August 2009, 08:55 AM   #50
tell me if this is balderdash.
Maximum output 30Vpk.
Maximum current into 2r0 15Apk.
Maximum current into 2ohm ~45Apk.
Maximum current through each output device ~5.6Apk (during normal use - no abuse).
typical gain @ 5.6Apk ~ 45 to 60.
typical maximum base current ~45Apk/45 ~1Apk.
typical NJW gain @ 0.1Apk to 5Apk, ~constant @ 100.
typical driver base current ~10mA+driver bias ~?mA. Try 20mA
typical impedance 30V/0.02A ~1k5 for normal drive conditions.
mjl21193/94 indestructable?? mikefromaus Solid State 2 16th January 2008 02:34 PM
FS: MJL21193 and MJL21194 - new zener_diode Swap Meet 9 27th December 2007 03:36 AM
MJL21193/21194s N-Channel Swap Meet 1 18th September 2005 03:04 AM
MJL21193 and MJL21194 HuntTheShunt Parts 1 5th December 2004 12:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
