Old 18th March 2009, 10:04 AM   #21
sajti is offline sajti  Hungary
Here You can find the driver stage for the bridged amplifier. It will be fully balanced from input to output.
Sajti
Old 18th March 2009, 11:01 AM   #22
roender is offline roender  Romania
roender's Avatar
Originally posted by AndrewT
A pair of output devices with an Re of 0r1 requires 260mA for optimal ClassAB bias.
Reduces to 114mA with Re=0r22 and to 53mA with Re=0r47.
Multiple pairs need these bias currents per device.
Andrew, you seems to forgot the internal parasitic emitter resistance. Also, the base stopper has a influence too.
With 0r1 Re and 2r2 base stopper the optimum bias current is 180...190mA
Old 18th March 2009, 11:15 AM   #23
roender's Avatar
This is the output stage linearity in relation with various values of Re, for a single output pairs (ref D. Self)
Of course, the figure is much more better as the number of pairs is increased, but the 0r1 re value is always better if the Vbe variation among output BJTs is in the range of 1..2mV
Re=0r47 is only for the cases when no OPS BJT matching is performed
Old 18th March 2009, 11:21 AM   #24
But how can I count with the internal parasitic emitter resistance?
Sajti
Old 18th March 2009, 11:24 AM   #25
The distortion is much better with more output pairs, but the load impedance is lower, because of the bridge connection.
And the 0R1 emitter resistor gives less protection against thermal runaway.
Sajti
Old 18th March 2009, 11:26 AM   #26
roender's Avatar
Sajti
You can't ...
You should measure the minimum distortion vs bias current.
The numbers posted above are from measurements and not from theory.
Old 18th March 2009, 11:27 AM   #27
Hi Roender,
I had not forgotten about the internal part of Re nor the effect that Rb has on it.
Your and others' earlier lessons are well remembered.
Old 31st March 2009, 09:22 PM   #28
First, I will try to reduce the number of the output devices, to reduce the capacitances, and get smaller size. I think that 4pairs for each amplifier module (8pairs for 900W/2ohms)will be enough. The peak current will be 8A for each pairs, 1ohm load for each module, with 32Vpeak output.
I put together some test circuit to measure the bias. 2pairs of FJL4X15 with 0.1ohm resistors, driven by MJE15032/33 biased to 80mA, predrivers are BC639/640 with 8mA. I use two transistors bias circuit with BD139/140.
The heatsink is about half sized I planned for one module.
The bias looks overcompensated. 26mV with hot heatsink, and if I cool down the heatsink it increase up to 38-40mV
Sajti
Old 2nd April 2009, 01:01 PM   #29
Smile Replacements for MJ15003/15004
Just checking something here...
Can I use an MJL21193/21194 to replace MJ15003/15004's
They only have a rating of 140V and wouldnt mind bumping it up to 250V. I would obviously have to compensate for a slightly lower W rating though...
Any thoughts?
Old 2nd April 2009, 01:20 PM   #30
wg_ski is offline wg_ski  United States
Default Re: Replacements for MJ15003/15004
Not if you want them to fit in the same socket. The MJ is a drop-in, the MJL is not.
In reality, in audio apps the MJ and MJL handle the same power. You just can't run the temp as high with the plastic pacakge.
mjl21193/94 indestructable?? mikefromaus Solid State 2 16th January 2008 02:34 PM
FS: MJL21193 and MJL21194 - new zener_diode Swap Meet 9 27th December 2007 03:36 AM
MJL21193/21194s N-Channel Swap Meet 1 18th September 2005 03:04 AM
MJL21193 and MJL21194 HuntTheShunt Parts 1 5th December 2004 12:11 PM
Copyright ©1999-2013 diyAudio
