How to drive 8 pairs of MJL21193/94? - Page 2 - diyAudio
Old 17th March 2009, 09:03 AM   #11
fotios is offline fotios  Greece
fotios's Avatar
Originally posted by sajti
I think to use 200mA bias, or higher
Do you mean 200mA Iqs per output device?!!
That is amazing if it is true! You will exceed the "extreme class AB" operation, for which - according to my experiments - a 50mA Iqs per output device it is enough.
I am wondering where you want to go. Near class A?
If yes, you have to use a ton of supply xformers and heatsinks!
Fotios
Old 17th March 2009, 09:08 AM   #12
sajti is offline sajti  Hungary
Fotios
No. 200mA bias for the driver. For the output stage I planned to use some 100mA for each output device. I have 2 pcs of 350mm long heatsinks, with forced cooling, and 1500VA toroid transformer, for each channel.
Sajti
Old 17th March 2009, 09:15 AM   #13
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
I have lot of NJW0281/0302 (about 70pairs).
Smarter to use them both as drivers and as output devices if you have so many.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 17th March 2009, 12:51 PM   #14
I put together the 1st version. Due the file is too wide here, you can see if follow the link
Sajti
Old 17th March 2009, 04:53 PM   #15
A pair of output devices with an Re of 0r1 requires 260mA for optimal ClassAB bias.
Reduces to 114mA with Re=0r22 and to 53mA with Re=0r47.
Multiple pairs need these bias currents per device.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th March 2009, 05:17 PM   #16
This means:
308W dissipation with 0R1
140W dissipation with 0R22
65W dissipation with 0R47
but higher emitter resistance increase the takeover distortion.
But You find the reason why no values on the emitter resistors...
Sajti
Old 17th March 2009, 05:28 PM   #17
...but higher emitter resistance increase the takeover distortion....
What is the question?
regards Andrew T.
Old 17th March 2009, 05:30 PM   #18
Nothing. I just wrote two different point of view...
Sajti
Old 17th March 2009, 05:45 PM   #19
AKSA will not agree with you.
He has adopted 0r47 for Re in many of his amp designs and retail offerings because he believes that value of Re is optimum for his style of amplifier.
regards Andrew T.
Old 17th March 2009, 06:24 PM   #20
But John Curl will agree. I have not that much experience. Another issue is the power loss on the emitter resistors, what I want to kepp as low as possible
Sajti
mjl21193/94 indestructable?? mikefromaus Solid State 2 16th January 2008 02:34 PM
FS: MJL21193 and MJL21194 - new zener_diode Swap Meet 9 27th December 2007 03:36 AM
MJL21193/21194s N-Channel Swap Meet 1 18th September 2005 03:04 AM
MJL21193 and MJL21194 HuntTheShunt Parts 1 5th December 2004 12:11 PM
Copyright ©1999-2017 diyAudio
