TGM Amplifier ?
TGM Amplifier ?
Old 16th May 2009, 01:08 AM   #251
Bigun is offline Bigun  Canada
Bigun's Avatar
TGM Amplifier ?
Thanks for the compliment OS. I'm quite pleased about it, although it is a dead simple circuit, it's the first I've ever built - for some reason my interest in electronics as a kid was mostly pulling things apart!
Chasis work is proceeding slowly, it's not the bit I'm most interested in. Grinding paint off pieces of chasis where they screw together to ensure earth connections to all pieces is a bit painful. Still, I have all the speaker binding posts mounted now.
Somebody was kind enough to give me a bag full of yellow LED's - I'm considering breaking from tradition and using a non-blue power indicator.
And, if things keep progressing, I will eventually have a platform to plug the amplifier prototype into so that it can be played with, broken, fixed and otherwise brought to a final design.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th May 2009, 04:42 AM   #252
Bigun's Avatar
TGM Amplifier ?
Any opinions on multi-channel volume control ?
I decided that the Lightspeed LDR approach is the best, but matching 12 devices is prohibitive. simplifying to a shunt system helps as then I need only 6, but I think it's an approach that exceeds the requirements of my HT project. I will use it in my next project, which will be stereo, when I can lavish more attention on just 2 channels and benefit from what I've learned so far. Well we'll see.
For 6 channels (5 amp channels + flow through to the active sub) I don't fancy finding an expensive 6-ganged pot.
Anybody used the digital potentiometers ?
I'm thinking of a fixed series resistor per channel and a digital resistor in the shunt position. The signal is less affected this way, to my understanding.
I would look at something like this for a simple up/down 100k resistor {http://search.digikey.com/scripts/Dk...BUJZ100RLCT-ND}
together with a shaft encoder {http://search.digikey.com/scripts/Dk...name=GH3071-ND}
and that's it !
thoughts ???
Old 17th May 2009, 05:07 AM   #253
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Where are the signals coming from? What is decoding the surround sound channels?
Old 17th May 2009, 05:58 AM   #254
Bigun's Avatar
TGM Amplifier ?
Signals are planned to come from Sony Blu-Ray S550.
The Blu-Ray guys have realized that many people already have Receivers which can't decode the higher quality sound tracks on BluRay and can't be upgraded via firmware. To cater to these people several Blu-Ray players incorporate full decoding on board. With the advances in decoder techniques etc. it's easier to do this in a integrated package now than it was before. Consequently this Blu-Ray player is able to decode and output full analogue 7.1 via RCA connectors. I believe the quality of the DAC's is pretty good. It also allows for some bass management, time delay, output level and speaker size to be set. These functions remove the need for a Receiver but they don't provide for convenient volume control.
The RCA outputs are quoted as "2V 10k Ohm" which I take to mean peak to peak max is 2V and the output impedance is 10k.
Not having a Receiver I plan to take the output from the BD player into the TGM via a suitable attenuator.
I was tempted to skip a volume control, I figured that I only need a toggle switch on the front panel that reads 'loud' and 'quiet' as these seem to me as the only relevant options
Old 17th May 2009, 06:46 AM   #255
Bigun's Avatar
TGM Amplifier ?
Here's a more graphical description of my hair brained proposal. It doesn't explain everything, but the key thing to note is the little diagram showing the 2-bit output from the encoder and that if you rotate it clockwise the timing goes from left to right, if you rotate anti-clockwise it therefore goes from right to left. And this makes all the difference !
There are some details to be understood, such as the power-up sequence for the digital potentiometer.
The cost looks more than reasonable for this approach, although there's no through-hole package available for the digi-pot (I don't consider this an obstacle).
However, it's volatile, resets to half-way on power cycling. That could be an issue, have to think about that.
But will it work ???
Old 17th May 2009, 09:20 AM   #256
currentflow is offline currentflow  United Kingdom
Looking at the AD5227 datasheet, the analogue signal range permissible on pins A,B,W is restricted to between GND and VDD. This means that your signal input (and signal ground) lines will need to be biased to around VDD/2 = 2.5V with respect to the IC's GND for maximum usable voltage swing.
There is a significant capacitance (140pF) between pins A and GND for this device. The resistor shown between 'signal i/p' and 'signal o/p' needs to be selected such that this capacitance doesn't degrade the high frequency performance too much. For example, if this resistor is 5.6K ohms, there will be a 3dB attenuation at 200KHz. Why not wire pins A,B,W as a conventional potentiometer?
As the device only draws 3 microamps from the supply, battery-backup could be investigated in order to overcome the 50% power-reset setting limitation.
Steve
Old 17th May 2009, 02:47 PM   #257
MJL21193's Avatar
Vishay has multi-ganged pots - stackable:
http://www.vishay.com/docs/51047/p9.pdf
Available at Digikey:
http://search.digikey.com/scripts/Dk...me=P9A1-10K-ND
Might be a lot less hassle.
Old 17th May 2009, 02:57 PM   #258
Bigun's Avatar
TGM Amplifier ?
Very handy feedback guys.
Digital Pot:
Looking at the part selection then, there may be a better, albeit slightly costlier option using the WMS7170100P-ND.
This offers a bit more resolution (100 linear steps), lower capacitance (30pF vs 140pf), non-volatile memory which I'll set as a one-time-programmable to minimum volume and as a bonus it comes in an easier to handle 8-pin DIP package. Updated schematic attached.
The need to put the voltage range in the right place shouldn't be too hard to arrange ?
Physical Pot:
I started off with this option, realizing I'll have to buy 3 dual-pots and then rebuild them into a 6-pot. These are plastic resistors and Vishay also make a cermet version which I think would be of better quality - but DigiKey don't carry this 'military grade' version.
The only reason I'm considering the digital potentiometer is because from what I've read, the physical pot is the worse choice for sound quality, the LDR's the best choice and everything else falls into the middle. People who have build relay controlled discrete resistor versions have been pleased with the sound quality increase over the physical pot.
Having not had the chance to compare however I'm at the mercy of my perceptions...
Old 17th May 2009, 03:42 PM   #259
MJL21193's Avatar
Physical Pot:
Which are almost certainly guaranteed to work.
If I'm not mistaken, Vishay makes quality parts - period. The P9A is for audio aps.
The P9S is for industrial (dirty, damp, chemical, etc.) use.
Once again, believing everything that is written (especially here!) is a slippery slope.
Old 17th May 2009, 07:13 PM   #260
Bigun's Avatar
TGM Amplifier ?
Perhaps the wisest words for a newbie on this forum
TGM Amplifier ?Hide this!Advertise here!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 17th May 2005 12:58 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
