TGM Amplifier ?
TGM Amplifier ?
Old 15th March 2009, 04:11 PM   #11
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Very nice, ostripper. I would omit C1.
Old 15th March 2009, 04:25 PM   #12
ostripper is offline ostripper  United States
ostripper's Avatar
That would create 100's of MV's offset at output. For those who
like no caps in signal path , an op-amp with adjustable
null point would do nicely.
OS
Old 15th March 2009, 04:41 PM   #13
Banned
ostripper,
I did mean C1 in post #9.
Old 15th March 2009, 05:15 PM   #14
ostripper's Avatar
You mean the 68p?
tried that , It seems to work good (no ringing),
loop response stays the same. IF you did use
a faster VAS device (KSC 3503..etc) Cdom might be needed.
But the slower 340 seems to do just dandy without..
OS
Old 15th March 2009, 05:57 PM   #15
Banned
ostripper,
all right.
Old 15th March 2009, 06:40 PM   #16
fjr is offline fjr
Default RE: schematic in post #1
Looks OK, but I think some mods are needed.
First, add an RC filter to the negative rail too, anyway you'll get high PSRR.
I'm not sure D1 is needed.
Then R1 must be = R9.
C4B would blow. Omit that.
A 100n...1u foil cap in paralel with R15 would be a good idea. R15's value is too low.
Add resistors is serier with C11 and C13 (1r...10r).
Use some lag compensation as OStripper suggested is his schema.
Omit L1 if the amp is stable driving capacitive load without the inductor. Or add a low value resistor in paralel with the inductor.
Use CFP Vbe multiplier or the bias will vary with rail variation.
I cannot agree with OStripper related to emmiter degeneration. I don't think they are needed in this circuit.
Current source and current sink for the LTP are not needed. Keep it simple.
An RC is needed in the input for lowing TIM (series R, paralel C).
Good luck!
Old 15th March 2009, 07:07 PM   #17
ostripper's Avatar
by fjr -Current source and current sink for the LTP are not needed. Keep it simple.
I suppose you could ditch the CCS if you were using
independant power supplies for each amp. But BG said
these would be part of a HT system (3-6 amps).
the current source I added does -60db /1k, with none
PSRR turns to CRAP. So, maybe even a better one
(LED, cap, 2 resistors) would be in order.
The sound of this topology would remain the same.
ASKA himself improved this design in later amps,
(aska100) by adding the CCS AND current mirrors.
OS
Old 15th March 2009, 07:40 PM   #18
Banned
fjr,
did you mean something like this?
Old 15th March 2009, 08:14 PM   #19
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Default Re: RE: schematic in post #1
PSRR turns to CRAP.
As mentioned, an RC filter will improve PSRR dramatically. That 100 ohm R (on one rail!) is a wee bit too big though, more like 10-22 ohm plus a 100uF or more cap.
Old 16th March 2009, 11:12 PM   #20
Bigun is offline Bigun  Canada
Bigun's Avatar
TGM Amplifier ?
sorry guys, this is probably snails pace for you. But first time ever using MacSpice this weekend - I have managed (after finishing the floor tiling) to get the LTP set up and obtain a dc analysis (see attached).
I am starting to understand how the LTP is the 'heart' of the amplifier, it determines many of it's properties as well as being a very elegant design element.
I can see that the total current through the LTP is 0.75mA but the imbalance is still a bit high (0.45mA T1 and 0.3mA T2).
I still plan to use AKSA as my 'guiding principle' so no constant current source. However, I read a posting in a forum that it uses 68k as the default load for the LTP. Looking at the limited data I have for 2N5401 I don't see why the lower current (0.5mA) would be a problem (does it hurt linearity or frequency response ?)
I understand that including two separate load resistors for each T1/2 aids performance by 'swamping the emitter resistance variations with current' (paraphrased from Rod Elliot).
I haven't figured out how to get spice to do an AC analysis (yet)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
TGM Amplifier ?Hide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
