AKSA said:Lisandro,
I used a BC550 npn, with collector to hot, and emitter to ground. Base was pinned with 1K to ground, and I seem to recall driving the base via a 1K resistor from a 1.5V. I noticed when off the collector had adverse effect on the sound quality.
Hugh
what off V for base?
if the signal was ground ref, the base needs to be a few volts more neg than the signal to prevent major dist from fwd biasing cb diode junction - a well impemented mute/bipolar sw need not add percepatable (much less "nasty") distortion
Hi All !
I am wonderig why the classic bilateral MOS Switches such as
the old CD4066 are unpopular fro this application....?
Especially if we consider there will be much more improved MosSwitches available.....would guess AD, BurrBrown, .....
...afraid of the distorsions due to voltage dependency of Ron ??
Bye
Markus
Bye
Markus
ChocoHolic said:Hi All !
Bye
Markus
And why not go with something like this pasive pre-amp by Peter Daniel
Trigon
I have only tried BJT shunt devices in a simulator and got very good distortion results.
As has been pointed out by jcx when the transistor is off the base must be well below ground level (may as well be negative supply rail) otherwise the signal will be clipped on the negative portion.
When ON the base current needs to be greater than the maximum peak current that will be sourced through the collector of the transistor during the negative signal swing. 10mA is probably a good figure.
I found that the BC550 does not have the best 'short to ground' properties when using them for signal muting, or switching to ground. Far better is the BC337 (or its SMD equivalent BC817). You can use them with the collector to ground and signal to the emitter (upside down) for lowest DC offset, or in the normal way with emitter to ground and collector to signal.
If the transistor should be open and still be able to deal with large voltage swings it is good to keep the base floating. That means that this transistor should be driven from a switchable PNP-current source or PNP inverted cascode transistor. If the current flows, the NPN transistor is switched on; if the current is switched off, the NPN base is floating and the transistor is able to deal with fairly large voltage swings, more than 10Vpp around ground, without the need for a negative supply voltage for the drive circuit.
This is without discussion of the sonic qualities of such a circuit. Such muting circuits are standard in e.g. CD player outputs, but have a bad reputation for sound quality.
Steven
- Idea for a better volume control...
