Old 14th March 2009, 12:34 AM   #91
mosfets is offline mosfets  Canada
Default Re: Re: Back in the 80's
Originally posted by Bob Cordell
The MOSFET amp you bought surely did not have 0.001% THD at 20 kHz. The spec you are referring to is almost certainly 0.001% at 1 kHz (assuming you recall it correctly). This very different, and much easier to achieve. It sounds like you have possibly fallen into the trap of 1 kHz THD specs.
Bob
I do not recall it being a MOSFET amp I do not recall it listed at .001% at 20kHz either. I do not recall falling in a trap. I guess I don't remember any of those things...weird
Any who, I'm just saying I don't pay much attention to specs like I once did. I think I can easily handle 1% THD without much bother. I would love to spend time studying the different harmonics in distortion, though. I envy guys like you Bob, who have dedicated so much effort and time to such things.
I love reading this stuff!
Old 14th March 2009, 01:48 AM   #92
andy_c is offline andy_c  United States
Banned
Originally posted by Lumba Ogir
My understanding says that the value of simulation in that regard is zero, because the conjugate variables, position and momentum of a moving particle cannot be determined simultaneously. In other words, spectral components are not traceable at any given time instant.
FFT analysis in SPICE gives the amplitude and phase of each individual harmonic (IOW, a full spectral analysis). It's not just a THD thing. You can do IM with it too - it's just a bit more effort. If you have questions about what it can and cannot do, just ask.
Old 14th March 2009, 03:32 AM   #93
Rafael L's Avatar
Very good Andy has done a good job in this forum with simulators
In the graph fig. appears as the measurement IMD , two different frequencies are applied to input, 60Hz and 7Khz (Standard default SMTPE) the residual near the fundamental 7KHz is the product IMD (highlighted yellow in Figure).
Old 14th March 2009, 05:33 PM   #94
Miles Prower's Avatar
Default Re: Re: Re: Back in the 80's
Given the time you bought it, and the description of how it sounded, I'd bet that it was indeed a MOSFET amp. I have one of those as well. It's sitting out back, and at least being useful as a home for field mice. The sound was gawdawful.
Seeing that no OPT is cheaper than the cheapest OPT, designers of these abominations simply adapted the SEPP-type output stage that works quite well with BJTs to MOSFETs. It's not a good idea, being that "complimentary" N-Channel / P-Channel devices are a good deal less "complimentary" than NPN / PNP pairs. For MOSFETs, use one type or the other, but not both in the same circuit.
Connect them to an OPT or use a Circlotron-type OTL final. Also, keep 'em well away from Class B operation. These thingies have hideous cross-over behaviour.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 18th March 2009, 10:01 AM   #95
destroyer X's Avatar
Default Thank you all folks..was interesting to read your ideas, your point of view
about this subject...the thread is exausted..the interested ones to comment have already made.
So, let the thread rest in peace and remember that i feel gratefull about your cooperation.
bye.
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 19th March 2009, 12:44 AM   #96
Pingrs is offline Pingrs  United Kingdom
Originally posted by ostripper
.options plotwinsize=0
is the same as
QUOTE]Originally posted by ostripper
turn off all "compression" in "control panel/compression"[/QUOTE]
isn't it?
Brian.
http://www.diyaudio.com/forums/showt...78#post1124278
Making Square Waves? Tom Danley Multi-Way 30 2nd August 2010 02:43 AM
Sine and square waves percieved pitch, why? baggystevo82 Everything Else 33 11th March 2005 04:18 AM
Basement Blaster doing square waves thoriated Multi-Way 2 6th August 2004 04:48 AM
Page generated in 0.12350 seconds (71.82% PHP - 28.18% MySQL) with 11 queries
