Where is the most linear region of Mosfets ?
When looking at transfer curves of power mosfets it seems they start to be linear at a few A, is that right ? |
#2 |
When you don't apply electricity to them.
#3 |
Seriously.
Can you find the most linear region of either of these? No semiconductors are particularly linear. The mfrs sort of craft their characteristics to suit different applications. I think the most linear thing you may find is the beta of some BJTs over certain Ic and Vce ranges. BJT Gm is exponentialish. MOSFET Gm is...square-law, cubed law, a bit of both, depends on the specific device. If you are designing a Gm buffer (source follower driven by a voltage source) I think your best bet is to try to linearize a MOSFET either with local NFB or source degeneration resistors. Eg: if you use a 200m-ohm source resistor the MOSFET Gm needs to be higher than 5 at the bias current (very roughly), and then you have to look at the Gm vs Ic graph to find the lowest bias current. BJTs are much better in this respect because their Gm is way higher for a given Ic...in this example you might need 2A bias for a FET but only 150mA for a BJT. Brian. |
#4 |
The lateral MOSFET seems to be better. This may justify their higher price.
#5 | |
#6 | ||
The IRF scale is not linear, so it is useless. Here is another IRF250. Starts to look acceptable at 5A and good at 7,5 A Quote:
And use a cascode to keep the dissipation down to 25W. Or better toast some 2SK175. |
#7 |
It looks like the curve of a bipolar transistor goes into the other direction, 2SC3281 for example, is it possible to combine both for something better ?
#8 | |
#9 | |
The one and only
and this varies from application to application. The curves cited here are only part of the information needed.
#10 |
What about a circlotron with a Mosfet on one side and a bipolar transistor on the other ?
| New Linear MOSFETs from IXYS | Kashmire | Pass Labs | 3 | 27th April 2007 10:39 AM |
| Width of crossover region | forr | Multi-Way | 40 | 3rd January 2007 12:52 AM |
| MOSFETs (active rectification) in place of diodes in linear PSU | UnixMan | Power Supplies | 44 | 18th January 2006 06:45 PM |
| Dvd Free Region | joz | Solid State | 0 | 6th April 2004 10:13 AM |
| Page generated in 0.10121 seconds (77.25% PHP - 22.75% MySQL) with 11 queries |
