I can't figure out how to configure PatchMix and/or my computer to get better crosstalk figures. I'm using Vista and E-mu 0404 PCI card. This is how it looks. It shouldn't be this bad, should it?
#2 | |
#3 |
input or output crosstalk?
loopback testing can mix the 2 cases did you use any termination on the input? - input shorting plug should give the ideal crosstalk any impedance between out and in will form a voltage divider with input's loaded impedance onboard analog switches likely would have parasitic coupling C another issue can be signal current from heavy load on the output causing V drop in common ground impedance the soundcard TRS stereo plugs can also be limiting because of the common ground contact resistance - load current on one output channel will couple to the "silent" channel through the gnd contact Vdrop a independent signal source can help - a portable mp3 player can be good for this |
#4 |
This is loopback, no load. I'm using the RMAA default in PatchMix. 24 bit and 96 kHz. I have to go to work now, but please give me some ideas of what's wrong.
#5 | |
| Paul's Lousy 60" Ribbons | poopydoopynoopy | Planars & Exotics | 42 | 27th September 2011 08:43 PM |
| Lousy woofer choice? help! | 14G-Dutch^ | Multi-Way | 17 | 4th August 2010 09:25 AM |
| OPT Grounding / Crosstalk | draperphoto | Tubes / Valves | 0 | 5th October 2008 12:07 AM |
| Interaural crosstalk | eStatic | Everything Else | 3 | 28th February 2008 04:53 PM |
| CS8420 is lousy? | inatightspot | Digital Source | 2 | 8th April 2005 12:04 PM |
| Page generated in 0.09547 seconds (74.47% PHP - 25.53% MySQL) with 11 queries |
