Old 5th March 2009, 01:34 PM   #21
iko is offline iko  Canada
iko's Avatar
Originally posted by Bonsai
With your latest circuit, PSSR will remain unchanged. What will improve is the output noise because you have filtered the noisy Zener.
Re the use of a big output cap. I prefer to use as big a cap as possible to keep the output impeadance low - especially at higher frequnceis where the open loop gain of the op-amp reduces. However, you have to watch that you do not introduce a pole in the loop with a low ESR cap - so this is where you have to try th e caps out to make sure the regulator remains stable.
I think some of the results we are getting in the sims are probably not acheivable (one sim showed better than -200dB!), but you should be able to get a a good, improved result.
I agree completely. the almost ideal world of the simulator can be very deceiving. To me is only a playground to test some ideas before reaching for the soldering iron. I'm not sure if I should allow myself to think that a circuit that simulates twice better than another will actually be better in real life too. Sometimes it is, and it's a matter of trying it out.
The zener noise isn't properly simulated... I'll see what I can do about that.
analog_sa, do you mean that your Jung implementation did not sound good? I wonder why we hear often that sound gets worse as soon as an opamp enters the equation. Well, someone with better listening skills than me will have to be the judge of this one. I listened to it this morning but cannot tell the difference between this and the few others I have
Old 5th March 2009, 02:00 PM   #22
iko's Avatar
Originally posted by salas
I would be glad to make one and subjectively ***** it when its final, and maybe there is a PCB.
salas, that would be great, I trust your ears anytime over mine. My wife thinks I'm a bit hard of hearing, which definitely helps when she dispatches house chores
Old 5th March 2009, 02:40 PM   #23
analog_sa's Avatar
Jung/ALW was my reference until last week. Since then i have built and started listening to something similar to the regulator syn08 proposed in the other thread. CCS is a 317 and i am not using the "weird" cap from his circuit. Opamp is 627. I like the sound better than the Jung in practically every respect. It is very similar to your circuit and i don't expect it to perform differently in any meaningful way.
Btw, R15 in your second circuit will work as intended. Now the zener noise is filtered and the opamp inputs get almost equal impedance in both ac and dc. I asked if you have simulated the performance of the CCS alone, ie impedance against frequency.
Not sure if any of the above has any real effect on sound or whether the simulations have any value. Circuit implementation will quite possibly determine the actual parameters.
Old 5th March 2009, 04:03 PM   #24
iko's Avatar
Please show me a sketch of the schematic, parts, values, and I'll run the sim, no problem.
Old 5th March 2009, 04:18 PM   #25
syn08 is offline syn08  Canada
Not at all. If you noticed, my circuit does not use a "follower" as parallel element, but it tries to provide some extra loop gain there. This means a N channel MOSFET instead of P channel and the opamp is flipped. Such a configuration provides at least 6dB of improvement in both output impedance and line regulation, at the penalty of a small reduction in the phase margin.
OTOH, OPA627 is not the best in such an application. I think I already mentioned, it may not have enough +/- output swing to correctly drive the MOSFET. Also, the bandwidth of OPA627 is limited, leading to suboptimal HF performance. LT1115, THS4031 or even LME49710 will do much better. Even the noise will be better.
The "weird" cap provides even more loop gain, but then you don't need to like it.
Old 5th March 2009, 04:46 PM   #26
iko's Avatar
Here's another result, the transient response to three parallel active loads I1, I2, and I3
I1 PULSE(25m 50m 0 10u 10u 1m 2m)
I2 SINE(25m 15m 500)
I3 SINE(25m 5m 4k)
All together give a current as shown in I(R1), and the regulator response in V(out).
Old 5th March 2009, 07:07 PM   #27
analog_sa's Avatar
I meant the CCS part of your regulator.
Old 5th March 2009, 07:28 PM   #28
analog_sa's Avatar
Oops. Sorry, should keep my eyes open. I completely agree that the ths4031 is a great opamp and probably also more suitable for this application but the ones i have are currently in use in one of my dacs and i am a bit reluctant to desolder them. Will order some more and try them out.
Old 5th March 2009, 08:53 PM   #29
iko's Avatar
I'm at a loss. Can you write it as V(part_number)/I(part_number) ? I just don't know which CCS you're talking about, sorry.
Old 5th March 2009, 09:02 PM   #30
iko's Avatar
In the meanwhile, this is how the ths4031 performs in this circuit.
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 44 7th October 2009 07:01 AM
Shunt reg: can I change the opamp? mark_titano Power Supplies 4 10th October 2005 05:31 PM
Copyright ©1999-2013 diyAudio
