Old 19th April 2003, 12:09 PM   #1
costiss's Avatar
Default 50w @ 8r / 100w @ 4r / 200w @ 2r
i desperately need a schematic of an AB/B class amplifier that could give 50w at 8Ù, doubling this figure until at least 2Ù ... yes, a beast in a compact case ... being able to drive the most current thirsty speakers on the world ... shall be a truly symmetrical, stable design... preferably on mosfets....
any help shall be appreciated
i am currently using 60,000 uF of capacitance in my preamplifier..
Old 19th April 2003, 03:57 PM   #2
paulb is offline paulb  Canada
How about www.aussieamplifiers.com ?
Old 19th April 2003, 05:19 PM   #3
moamps is offline moamps  Croatia
Default Re: 50w @ 8r / 100w @ 4r / 200w @ 2r
in Elektor 10/90 was published "MEDIUM POWER AMP"
with some caracteristic:
60W/8E
110W/4E
170W/2E with 0.1%THD
PS is +/-24V
IM (1W) 0.01%
SR 30V/s
DF 100 on 20kHz, 200 on 100Hz
output devices BJT pairs (3x) BD911/912
Old 19th April 2003, 05:27 PM   #4
mrfeedback's Avatar
Default Ya Don't Get Ought For Nought.
To double power into lowering load impedences, a 'perfect' power supply is required.
This requires over rated transformers and smoothing caps, but pays nice dividends at all power and load impedence levels.
The downside is that this adds much cost.
IOW the supply voltages should not sag with lowering load impedence and power delivery.
Eric.
I believe not to believe in any fixed belief system.
Old 20th April 2003, 10:45 AM   #5
costiss's Avatar
i do know this mr feedback... its 12A peak @ 24v on a 2R load, plus a 50% margin 18A @ 28VDC 18A @ 21VAC -> 378VA per polarity... the point is, it is not going to run into a 2R load all the time.. most likely into the 8r the b&w 603 present.. the overspecification is to ensure that the amp will be stable with any (rational or irrational) fluctuation of the speakers impedance...caps? 4 x 47000uf @ 35V is enough (2ch) i think.....
Old 20th April 2003, 05:59 PM   #6
Werner is offline Werner  Europe
Being able to double output power into halving impedances and
stability are two entirely different things.
Old 21st April 2003, 02:34 AM   #7
djk is offline djk
djk's Avatar
"i desperately need a schematic of an AB/B class amplifier that could give 50w at 8Ù, doubling this figure until at least 2Ù ... yes, a beast in a compact case ... being able to drive the most current thirsty speakers on the world ... shall be a truly symmetrical, stable design... preferably on mosfets....
any help shall be appreciated"
Are you hung up on mosfets?
The GAS Son of Ampzilla, Krell KSA50, and the Leach all come to mind.
All are full complementary from input to output using regular bi-polar transistors.
The GAS:
http://home.kimo.com.tw/skychutw/amp...pzilla_sch.jpg
A Mark Levinson design, the same basic topology with J-fet inputs:
http://home.kimo.com.tw/skychutw/Cir...schematics.jpg
If you insist on mosfets for outputs, the Hafler XL280 is the same topology as the Mark Levinson, just with fet outputs:
http://www.hafler.com/techsupport/pd...80_amp_man.pdf
An all hex-fet variation:
http://www.passdiy.com/pdf/A75p1.pdf
http://www.passdiy.com/pdf/a75p2.pdf
What I use:
http://users.ece.gatech.edu/~mleach/...aphics/ckt.pdf
http://users.ece.gatech.edu/~mleach/lowtim/
I get 450W/2R from three pair of outputs. I would strongly suggest using a regulted high voltage tier for the front end (like the GAS, XL280, and A75).
A 30-0-30V 400VA transformer per channel with 15,000~30,000µF is all you need for 200W/2R. Two pair of outputs.
Old 21st April 2003, 09:41 AM   #8
mrfeedback's Avatar
Default Leach amp + 4 X 47,000uF = Fine.
Yes 4 X 47,000uF should be all the snot that you need - many high power pro-amps run much less than this - like 30,000uF total for 2 X 1000W into 4 ohms.
With intelligent power supply and earthing arrangements, this should give pretty much limitless performance.
The Leach amp that Djk uses, although not mosfet ought to be good - I have not heard one but I do bellieve that they are pretty good.
Use 2SA1943 and 2SC5200 output transistors and it will never let you down.
Eric.
Eric.
Old 21st April 2003, 09:51 AM   #9
PMA is offline PMA  Europe
PMA's Avatar
Default Re: Ya Don't Get Ought For Nought.
Eric.
Eric,
that's right. And have a look at the SOAR of output transistors, take to the account reactive compound of load impedance.
Pavel
Old 21st April 2003, 11:41 AM   #10
mrfeedback's Avatar
Default easy Soloution
Just run enough output transistors, and impedence compensate the drivers - and no problems.
Eric.
200w Gem serosmaness Solid State 0 30th July 2006 03:39 AM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 11:57 AM
Simple, powerful (100W-200W into 8ohm) amplifier schematic needed ddog Solid State 14 23rd April 2004 05:36 AM
Page generated in 0.11297 seconds (82.20% PHP - 17.80% MySQL) with 11 queries
