Old 4th March 2009, 06:30 PM   #1
seafire is offline seafire  Mauritius
Red face Mosfet Replacement
WHAT MOSFETS DO I REPLACE WITH?
Hi all I am still stuck.My pm 94 Marantz popped 1 mosfet 2SK405-This is paired with 2sj115.Anyone know were i can find some replacements in the USA or UK or anywhere for that matter?.It has been suggested that I replace with 2SK1529-2SJ200.Can anyone with the know how please tell me if this replacement will work or if they can find me the original K405.Or can anyone suggest another replacement for these fets...please guys this newbie is desperate
Old 4th March 2009, 11:26 PM   #2
Banned
seafire,
2SK405, the predecessor of 2SK1529 is now obsolete. 2SK1529 would be the very best for a (hopefully) trouble free replacement, bearing in mind that these types are somewhat different from "common" vertical MOSFETs.
Old 5th March 2009, 03:16 PM   #3
Banned
seafire,
you should check and readjust the bias voltage, which is a good thing to do anyway. I don`t expect any other problem. You are going to replace all FETs, aren`t you?
Old 5th March 2009, 04:47 PM   #4
Yes Lumba Ogir
I will replace all mosfets with 2sk1529/2sj200.Also should I replace the drivers on the driver board? they are c2682 anda1142.They say the reeplacement is 2sd669a and2sb649a is this correct? Thanks in advance seafire
Old 5th March 2009, 05:10 PM   #5
Banned
seafire,
it is not correct. 2SSC669/2SB649 is to be used in current stages. Please keep 2SC2682/2SA1142 unless they are defective.
Old 5th March 2009, 06:01 PM   #6
housing is offline housing  Hong Kong
Hi Seafire,
Contact me via email if you are sure that only the output pair 2SJ115/2SK405 is toasted. I have what you want. What's the grade of the pair, Y or O?
Old 5th March 2009, 09:27 PM   #7
Hi Lumba and Housing I have sent you both emails thank you for the help so far Seafire
Old 5th March 2009, 09:56 PM   #8
homemodder's Avatar
A much closer replacement for the 1142 pair would be 2sa1209 and 2sc2911, available at rs electronics.
Greetings from ex SA
Old 6th March 2009, 04:47 AM   #9
Banned
seafire,
From Sanyo
2SA3600/2SA1406 very nice.
2SC2911/2SA1209 as already proposed
2SC3953/2SA1538 for higher currents
From Toshiba
2SC3423/2SA1360
From Hitachi
2SD1609/2SB1109
Mosfet replacement palesha Solid State 8 25th January 2011 08:41 PM
replacement mosfet recomendations?? psychosteve Solid State 58 1st March 2009 12:06 AM
Mosfet Compatible Replacement JhonDoe Parts 2 29th January 2009 11:16 PM
RF Power 300 Mosfet, replacement FETs Mike1008 Car Audio 1 6th June 2006 04:34 PM
MOSFET replacement carlmart Solid State 0 9th October 2001 10:13 PM
Page generated in 0.09609 seconds (73.93% PHP - 26.07% MySQL) with 10 queries
