#11 | |
#12 |
Did it Himself
Yes and so can the LM317. However, in practical reality you must limit the input voltage to the max specified because as soon as you put a cap on the output of the regulator, at startup it holds the output at close to zero volts for a short time which will cause differential limits to be exceeded if your input is too high.
It may survive for a while but soon it may well go pop.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#13 |
Excellent point. I was also wondering about the output cap.
#14 |
Well, simplest would be to use an appropriate Zener across the regulator to clamp the differential voltage (power-Zener!).
In that case I would definitely recommend to limit current inrush, maybe simplest by using thermistors or relay bypassed resistors. But that also depends on capacitance you put after the regulator. Maybe a suitable thermistor in series to the Zener is sufficient. However to build such a thing reliably would need a little experience and some trial and error. Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets F5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#15 | |
The capacitors of the regulators are in parallel with the bank. In this way, using a TSR and a regulator with zener clamp would perhaps be a reliable and easy approach to the problem. JPV |
| Lost Thread-High VOltage Regulated Power Supply | LinuksGuru | Tubes / Valves | 2 | 21st June 2009 01:48 AM |
| Links to High Current Regulated Power Supply? | lgreen | Solid State | 1 | 25th January 2005 12:11 AM |
| high performance regulated supplies for power amps | jez | Solid State | 14 | 5th January 2004 03:22 PM |
| high-voltage regulated dual power supply | zzz | Solid State | 1 | 17th September 2002 01:15 AM |
| Page generated in 0.13111 seconds (80.93% PHP - 19.07% MySQL) with 10 queries |
