Hi I'm a newbie I have a Zen circuit and I'll use it as a Headphones amp,only problem is there is alot of hum
a friend told me it is a ps problem,what kind of ps filter should I use and how much capacitance the circuit is biased at 1A please help to fix hum thanx
#2 |
Hi Again
please help me There is another problem I gave the circuit to a friend and he told me the amp frequency response is only about 10khz He said the volume control and the g-s capacitance of the fet form a low pass filter, now I dont know what else to do with it,the first problem I increased the capacitance of the ps but there is still hum can you help with these two problems kind regards |
#3 |
kim707, is that a Pass type Zen circuit? If so ask a moderator to move this thread to the Pass section of the forum where you most likely will receive help.
#4 |
Hi kim,
I get the feeling you already have a competent friend at hand, maybe he/she can help you a little more? If adding caps don't help to get rid of your hum, then grounding is most likely your issue. Your friend has good tips for this as well, I'm sure Have fun, Hannes
fresh matched IRFP240/IRFP9240 fets F5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
| ZEN-like headphones amp | tortello | Pass Labs | 195 | 28th January 2012 06:58 PM |
| K-12 with headphones? | ambience exists | Tubes / Valves | 3 | 15th May 2009 03:21 AM |
| T-Amp for headphones | alan-ralph | Class D | 1 | 18th June 2005 09:00 PM |
| for headphones | Prune | Pass Labs | 4 | 14th September 2003 07:41 PM |
| Which headphones are the best | Bull | Everything Else | 11 | 8th December 2002 09:17 PM |
| Page generated in 0.07432 seconds (72.81% PHP - 27.19% MySQL) with 10 queries |
