hi all
i,m thinking about building the above amp and would like to kinow if its possible to bridge it to make 40w per side by using 4x module kits i also need it to be balanced and from what i understand (bugger all) it would be easy to set it up for balanced input if i do it this way is this possible or am i just dreaming (as usual) regards sheafer |
#2 |
no takers ?
surely someone here must have some experiance with this amp |
#3 |
slr 5000
I doubt that anybody would have attempted that. How do you propose to get rid of >200W of heat ? SandyK |
#4 |
wasted energy, think globe warming think efficiency better for the earth. then use class-T.
#5 |
hi all
ill get rid of the heat via big heatsinks i have 4x conrad 350mm x 150mm so thats not an issue as for global warming im not concerned ,i care about sound quality and if i have to burn 1000w of heat to get it then so be it . i dont buy into the whole global warming thing anyway i think its just a natural cycle of the earth . |
#6 |
slr 5000
I agree with your comments about sound quality, as I have a SC15W/Ch. However, I wonder how many members realise just how much quality sound you can get out of even a 15W/Ch Class A ? Certainly much more than many people can comfortably use in a domestic situation,without the neighbours, or "she who must be obeyed " complaining. SandyK |
#7 |
hi sandy k
they will be used for driving some manger transducers in an active setup so i suppose 20w will proberbly be enough ,im just going overboard as usual how do you find the sc 15w,ive read some good reports but i really need the balanced inputs as the whole system is ran threough a dbx 260 and i thought that using 4x modules bridged would also make it easy to configure it for ballanced inputs as well i may be way off as usual with this assumtion though |
#8 |
slr 5000
A tweaked SC 15W can easily outperform a standard SC 20W. Manger drivers can sound very good indeed, although the ones I heard were in an open baffle as a temporary measure. I think it may have been the Class A that was pressed into service on this occasion, with quite good results for a temporary speaker lash up. According to SC, even the SC15W is capable of 25-30W into 4ohms, but only in Class A up to 7.5W into 4 ohms. SandyK |
#9 | |
#10 |
does this mean that the sc20 or 15 is not pure class a but a class a/b that switches after say 7 watts
hi luke a worked slr5000 torana , a pure class a amp (nelson pass or other) and a cold can of carlton draught = heaven on earth unless your a greenie then its a toyota prios and lentiles |
| 1500W RMS Class D PCB - which Class D Driver Chip is it ? | mosfetsound | Class D | 11 | 1st April 2011 11:17 AM |
| Measure the output of a bridged class D | ocool_15 | Class D | 5 | 20th April 2008 07:12 PM |
| Bridged class D on small mfets | VEC7OR | Class D | 26 | 2nd October 2006 10:30 PM |
| class d chip amp | sagarverma | Chip Amps | 19 | 23rd October 2005 05:08 PM |
| Page generated in 0.09582 seconds (78.94% PHP - 21.06% MySQL) with 10 queries |
