#11 |
Thanks everybody, I liked very much the looks of the aluminum potted transformers of the Pioneer A-878 amps
#12 | |
It's good that you like them, because any of these potential amp topologies really require a separate trafo for each channel. make sure the chassis is heavy enough to handle it .
#13 |
Unfortunately those trafos have no center tap.
In that amp there is one trafo per rail instead of one trafo per channel. |
#14 |
Crown grounded bridge requires one trafo (or at least isolated windings) per channel, and requires no center tap. The QSC also requires isolated supplies, and can be built without the center tap. The QSC class H varieties require center taps, but the basic transnova circuit does not need it. Thier old circuits just used two caps (and didn't even bother with the equalization resistors).
| Battery PS: Virtual ground or single supply? | Dominique | Power Supplies | 2 | 5th May 2007 11:34 PM |
| Connecting Virtual Ground Circuits with True Ground circuits?? | Minion | Solid State | 1 | 12th February 2007 01:28 AM |
| Decoupling cap placement - virtual ground dual op amp? | Triophile | Solid State | 1 | 27th March 2006 06:30 AM |
| virtual ground | codacola | Parts | 4 | 1st June 2005 08:38 AM |
| virtual ground...help | jsteigs | Chip Amps | 6 | 3rd February 2005 10:49 AM |
| Page generated in 0.08438 seconds (73.46% PHP - 26.54% MySQL) with 11 queries |
