Figure 1 (below, second post) shows a section of the
AV800 amplifier where the predrivers stages get their power from the +90v and -90v power supply via the 100 ohm resistor/diode network and 220uf capactor (D8, R17, C2). Question: Figure 2 (below, 3rd post) shows the predriver stage being powered by a seperate power source that is also +90v and -90v. Is figure 2 a valid design method? When the output stage drives, the large transformer supplying +90v/-90v will sag down to rms value under severe load, perhaps as low as 65 - 70 volts. Can the predrive stage operate at a constant +90v volts *and* the output stage operate at 65v under load ? Will the voltage mismatch cause problems? Av800 schematic http://www.aussieamplifiers.com/downloads/AV800.pdf |
#2 |
Figure 1
#3 |
Figure 2
#4 |
10 PRINT "HELLO WORLD" 20 END |
#5 |
10 Print ''Hi, hear you !!"
20 End !!! Hi, I have used a similar scheme with separate supplies for the two stages. In my case I used 'separately' derived supplies. I had no problems and never blew any transistors. However, the higher supply of the driver would pull the base of the OP trs above their supply voltage. This would happen when you clip. I don't remember what the waveform looks like under clipping conditions or the recovery waveforms. But the bottom line was that the amp sounded very good and I did play it clipped at times without any fireworks or disgusting sounds. I am building a new amp with this (powersupply) scheme. If you are interested I can post the results. Cheers.
AM |
#6 |
If you wanted to you, could just make C1 and C2 much much bigger, so whenever the main rails dipped a bit the pre-driver rails would stay put for a sufficiently long time. Diodes D7 and D8 allow the main rails to go lower momentarily without sucking the voltage out of C1 and C2 at the same time.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#7 |
I would run the front end off 100v rails. You are loosing about 8v per rail. This would raise the output of amplifier before clip.
Regards, Jam |
#8 | |
Would too much capacitance at C1 and C2 cause problems, lets say I put 5,000 uf - 10,000 uf on each predriver rail ? |
#9 | |
Cool, thanks for the tip. I'm not an amp design guru, how do you calculate the loss of 8v ? You are saying that if I keep this VAS stage at 100v with it's own independent power supply and connect the output stage to the large power supply, under load the output stage sags, lets say down to 65v, clipping on the output would be at ~100v not ~65v ? Is this how it works? |
#10 | |
| Hi-end GM70 amplifier with only 2 stages | audiodesign | Tubes / Valves | 101 | 21st May 2011 07:42 PM |
| xpp amplifier question | woody | Tubes / Valves | 0 | 18th April 2009 11:26 PM |
| Noob Question on Driver Stages | Toyman_PA | Tubes / Valves | 2 | 14th August 2004 08:47 PM |
| Another way of making the output section with class A predriver | JensRasmussen | Solid State | 10 | 5th August 2004 10:04 PM |
| predriver stage in power amps | ergo | Solid State | 5 | 11th May 2001 07:13 AM |
| Page generated in 0.19596 seconds (54.02% PHP - 45.98% MySQL) with 11 queries |
