Old 2nd March 2009, 12:51 PM   #1
h_a is offline h_a  Europe
h_a's Avatar
Default JFet matching and measured distortion - Part 2: LTP
...or the death of jfet-matching?
2nd part that looks at matching jfets and distortion performance in simple circuits (1st part was JFet matching and measured distortion - Part1 ).
It is my pleasure to bring you something more interesting, the differential pair (aka LTP).
And yes there's is benefit. Distortion is reduced by using matched jfet-pairs.
And no it's not much.
The details:
(See schematic below) A simple LTP consisting of 2x Toshiba 2SK369GR jfets (same as last time), no source degeneration, a simple tail current source using a ZTX450, setup for 1mA. Load resistors of 100 Ohm were chosen to keep Drain-Source voltage variation low as the used rails (0-13V) do not permit the use of a cascode.
Old 2nd March 2009, 12:55 PM   #2
h_a's Avatar
THD+N plot
For starters the THD+N plot.
Jfets A+B represent the worst case where 2 randomly chosen jfets have largely different IDSS; in this case THD+N is constantly higher by about 1.5% absolute.
Jfets B+C is so-so matched (to 0.3 mA) and is nearly indistinguishable from the best matched pair in the comparison, jfets C+D (0.068mA difference in IDSS). If you look closely, you see that this closest pair actually performs worse for larger input signals than the mediocre matched B+C pair (look at 180-200mVrms).
To summarize the plot, avoid largely unmatched jfets for LTP-use, but even mediocre matched pairs can work better than tightly matched ones. So to reliably get better performance by matching, one need to use a distortion analyzer for verification.
One does not get automatically better performance.
Old 2nd March 2009, 12:57 PM   #3
h_a's Avatar
Distortion spectra
As there's often the discussion of distortion spectra, I might contribute some data as well.
Here the overlay of the mediocre matched pair B+C (blue) and the tightly matched pair C+D (red). No notable differences. Small differences for 4th and 6th order; odd orders largely unchanged.
Finally the spectra of the worst case pair: large 2nd order distortion compenent,distortion cancellation no longer effective.
Old 2nd March 2009, 01:00 PM   #4
h_a's Avatar
Part 3 would be the complementary case, however I do not have an appropriate power supply in the moment. I can build one, but as I will be busy the next weeks this has to wait a bit.
Summarizing the results, distortion is easily held under control by using even only medicre matched pairs (within about 0.5mA, just like Borbely sells them). Closer matching is not guaranteed to give better results. Of course that only applies to distortion. How important that is to 'good sound' is to everybody's taste.
Of course discussion is welcome
Again a big thank you to Mr G, who made the fun possible.
Have fun, Hannes
Old 2nd March 2009, 01:06 PM   #5
h_a's Avatar
Ups, sorry spectra for the worst case were missing.
So here they are:
Finally the spectra of the worst case pair: large 2nd order distortion component, distortion cancellation no longer effective.
Old 2nd March 2009, 01:07 PM   #6
PMA is offline PMA  Europe
PMA's Avatar
Your circuit in
http://www.diyaudio.com/forums/showt...41#post1761341
is a perfect example how NOT to design with JFETs.
Old 2nd March 2009, 01:11 PM   #7
h_a's Avatar
Of course not.
AC-coupling is no fun, higher rails, cascode would be nice etc. - however the comparison is still valid as all pairs are equally affected.
And the comparison was the whole point in doing this
Have fun, Hannes
Old 2nd March 2009, 01:16 PM   #8
you have compared similar and dissimilar Idss.
What about transconductance comparison?
I have found it very easy and very quick to match Idss to any tolerance.
When comparing well matched pairs at any current different from Idss, the Idss matching turned out to be nearly useless. It simply grouped the devices into batches.
Getting a loose match of transconductance AND Idss was difficult.
Getting a close match of transconductance over a range of Id is very laborious. I don't believe it can be done by comparing graphs/testpoints taken with individually measured devices.
It needs a pair matching jig and careful attention to matching currents and dissipations and temperatures.
regards Andrew T.
Old 2nd March 2009, 01:25 PM   #9
h_a's Avatar
Sure, it's doable and of course it would also be interesting. There are lots of things one could have a look at.
I'm however especially curious about the effect of simple things, these that often give most benefit. More sophisticated methods start often the diminishing returns.
Anyway, the data does not suggest that curve matching would significantly improve distortion performance.
I think that one can do that to enjoy the symmetry, but otherwise there seems nothing to be gained.
Have fun, Hannes
Old 2nd March 2009, 01:32 PM   #10
using similar Idss devices is not comparing the performance of matched devices.
regards Andrew T.
JFet matching and measured distortion - Part1 h_a Solid State 22 27th March 2009 06:41 PM
Ono JFET matching AuroraB Pass Labs 12 26th July 2007 12:20 PM
12'' drivers Distortion measured! <link> mikee12345 Multi-Way 5 28th August 2003 09:19 AM
Measured my Leach Amp distortion THD today BrianGT Solid State 3 12th April 2002 08:03 PM
Page generated in 0.19038 seconds (50.99% PHP - 49.01% MySQL) with 11 queries
