#591 |
Are there models that reveal this problem?
Could it be modeled as a resistance in series with the semiconductor parasitics or is it just a result of the larger capacitances at low voltages? - keantoken |
#592 |
Ask Cordell, he's the one that taught me about the MOSFET drain problem.
If anyone's models might have such a reality check.. Anyways, think MOSFET for a sec. Construction often almost symetrical. Why should Cgd ever be less than Cgs ??? It is only bias on the drain that causes the shape of the channel to shift capacitance toward the source. Take away this bias, and channel shape reverts to symmetry. BJT problem is minority carrier storage, I'm not sure if its modeled or not? I do not think Vce can be less than Vbe unless the base is first saturated. Then currents intended to control the BJT have a delay while those carriers are added or flushed. I don't know if this would misbehave like a capacitor, or something else entirely? I would expect any such models probably a .subckt Don't swet it overmuch, Allison only needs Darlington or MOSFET outputs to assure enough collector voltage for the error amplification stage. And Darlingtons won't suffer unsimulated behavior till much closer the rail than a MOSFET. Last edited by kenpeter; 5th March 2011 at 03:29 PM. |
#593 |
Not knowing the actual mechanism of the issue for BJTs is a problem. A series impedance with the capacitances will require more voltage drive. This impedance may be nonlinear. However, a simple increase in capacitance can be dealt with just by increasing current bias to provide for more current drive.
- keantoken |
#594 |
EKV MOSFET Model - Wikipedia, the free encyclopedia
http://www.cordellaudio.com/book/Book_Back_Cover.pdf http://ekv.epfl.ch/page-44146-en.html I see LTSpice listed as supporting this model type. Last edited by kenpeter; 5th March 2011 at 04:06 PM. |
#595 |
I just flipped through Cordell's book and it doesn't seem to mention anything other than an increase in capacitance at low voltages for BJTs. I can deal with an increase in capacitance, and this is modeled.
Vcesat is below 10mV at 10mA for most small-signal transistors. This is at beta=10 in most cases. In simulation operation at Vcb=0 is usually fine, with tolerable increases in junction capacitances. I figured this was still okay because Vcesat is usually so low. I have never seen an in-depth description of what you describe and how bad it can be expected to be at a given operating point. So I can't do anything about it; I don't know what, where, or how much. - keantoken |
#596 |
kenpeter, specifically what issue are you talking about? Is it an issue with both BJTs and MOSFETS? Does it have a name?
#597 |
I'm not sure I see the difference where Cordell EKV model handles low drain voltage?
Cgdmax is not that much different, Cgdmin got roughly ten times smaller??? Default LTSpice Models Linear Technology - Design Simulation and Device Models .model IRFP240 VDMOS(Rg=3 Vto=4 Rd=72m Rs=18m Rb=36m Kp=4.9 Lambda=.03 Cgdmax=1.34n Cgdmin=.1n Cgs=1.25n Cjo=1.25n Is=67p mfg=International_Rectifier Vds=200 Ron=180m Qg=70n) .model IRFP9240 VDMOS(pchan Rg=3 Vto=-4 Rd=200m Rs=50m Rb=100m Kp=8.2 Lambda=.10 Cgdmax=1.8n Cgdmin=.07n Cgs=.77n Cjo=.77n Is=76p mfg=International_Rectifier Vds=-200 Ron=500m Qg=44n) CordellAudio.com - SPICE Models * IRFP240C VDMOS copyright Cordell Audio December 6, 2010 .model irfp240C VDMOS(nchan Vto=4.0 Kp=4.8 Lambda=0.0032 Rs=0.01 Rd=0.1 Rds=1e7 Cgdmax=2600p Cgdmin=10p a=0.35 Cgs=1250p Cjo=3000p m=0.75 VJ=2.5 IS=4.0E-06 N=2.4) * * * IRFP9240C VDMOS copyright Cordell Audio December 6, 2010 .model irfp9240C VDMOS(pchan Vto=-3.76 Kp=9 Lambda=0.004 Rs=0.064 Rd=0.1 Rds=1e7 Cgdmax=1200p Cgdmin=15p a=0.26 Cgs=1130p Cjo=2070p m=0.68 VJ=2.5 IS=4.0E-06 N=2.4) Cordell also supplies a separate .model for the body diode that doesn't appear in LTSpice. Visit his page, get his complete file, not this except for discussion purpose only. BJT saturation info was in an old book, I don't have anymore or can't find. Maybe I loaned to Zobsky??? Yeah, sounds plausible, that'll be my excuse! No, seriously... I think it was like GE or something... Last edited by kenpeter; 6th March 2011 at 12:12 AM. |
#598 |
By the way, in your junk box there are:
RCA Transistor Manual (Technical Series SC-10) 1962 RCA Recieving Tube Manual (Technical Series RC-26) 1968 One of these days or whenever... The book with the info I was hunting for was GE, I think... Unfortunately, RCA didn't go into detail on that aspect. |
#599 |
Page 43 (RCA SC-10 1962), halfway down the right side:
"The storage time Ts is the length of time that the output current Ic remains at its maximum value after the input current Ib is reversed. The length of storage time is essentially governed by the degree of saturation into which the transistor is driven and by the amount of reverse base current supplied." Not much detail there... Maybe this? http://books.google.com/books?id=205...lector&f=false Last edited by kenpeter; 6th March 2011 at 12:43 AM. |
#600 |
D'oh, how could this be complete without the Baker clamp?
Baker Clamp Maybe even better with the recent zero recovery time SiC diodes (from Cree)... (I wonder if those would be good in the Allison too?) I would never operate a power BJT at low Vce, because simulation and datasheets readily show the bad behavior. However I understand saturation only becomes a problem at say >40mA as long as you keep above Vcb=0. It sounds to me like saturation occurs when the BC junction begins to forward-bias, and this causes the transistor to lose most of it's redeeming qualities. Those are VDMOS models, not EKV, if I am not mistaken. LTSpice added some parameters to include subthreshold simulation some time back, I remember on the yahoo group... Diffusion delay sounds like series resistance, sort of... Thermal transfer in power semiconductors is a diffusion process. Looking at the switching times from this datasheet doesn't seem to indicate low Vce=low switching speed, given appropriate base drive. The problem is finding datasheets with detailed switching charts, for transistors not unlike those we use in audio. http://www.fairchildsemi.com/ds/2N/2N3904.pdf - keantoken |
| Best MOSFET for output stages | millwood | Solid State | 136 | 4th June 2010 07:54 AM |
| Cascode Output Stages | pietjers | Solid State | 118 | 20th April 2008 05:56 PM |
