Closed Thread
Old 28th February 2009, 09:06 PM   #1
packer is offline packer  United Kingdom
Default What is this Amp design called?
I have an FBT MAXX 4a powerd speaker which keeps blowing FETS (Q3). See page 3. I have never seen this design before.
especially passing audio through digital Gates See pre amp section.
I would like to know what the design is called and then search for some theory on operation. Also I would like to know what voltages to expect at each junction.
Even with a lamp in series with the ac in it shorts Q3, D5 & U2
The circuit was too big to Upload so link below
SCHEMATIC DOWNLOAD
All help would be be most appreciated.
Old 28th February 2009, 10:13 PM   #2
infinia is offline infinia  United States
infinia's Avatar
Hi
It looks like a Class D amplifier output stage.
It's basically a pulse width modulated power switch with a low pass filter.
U2 is a MOSFET driver with high side and low side gate drive.
Check Q4 and for any low impedance on outputs.
If OK, check with O-scope after disconnecting the 60V drain supply.
EDIT>If the otherside is working, use it for a reference.
Cheers
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 1st March 2009, 12:11 AM   #3
Speakerholic
Cal Weldon's Avatar
Mission accomplished, thread closed as requested.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Closed Thread
what is this called skullkeeper Parts 1 23rd April 2009 11:28 PM
What is this cap called? intensem1rider Parts 6 20th March 2008 05:34 AM
What's it called? Cal Weldon Multi-Way 10 16th June 2007 05:29 PM
a band called Ra Shpoop Music 3 7th July 2005 11:29 AM
Page generated in 0.08772 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
