Arcam Delta 290
Hi
I don't want to start a new thread so pardon.
I have old Arcam delta 290 Power amp.
I do not use it currently and was planning to sell, but I have an idea of tweaking it a bit with newer parts and see if any change to the sound occurred.
Can I ask members of this forum is there any particular component upgrade or swap for new one would bring benefit of improved sound ?
I have attached service manual and few pictures (big) @ dropbox .
https://www.dropbox.com/s/sdxhmww71q2ire1/IMGP2610.JPG
https://www.dropbox.com/s/op053pji9jgekd1/IMGP2612.JPG
https://www.dropbox.com/s/7qw7wp415uc6sz6/IMGP2616.JPG
Service manual
Thank you
  • user-manual-ARCAM-DELTA 290-E.pdf
As I can't see the schematic I'm shooting off the hip a bit here.
Most of the Arcams were Class A/B Mos-Fet designs with single complimentary P-Type + N-Type outputs.
These can generally be improved upon by 1). Increasing the solidity of the PSU which has been discussed above and 2). Doubling up the output devices which improves the damping factor and the output impedance.
