Old 25th February 2009, 10:14 PM   #1
Default Please Check my soldering!
Hi, I'm fairly new to soldering and I often see on forums/soldering guides people criticising soldering in pictures saying that it is rubbish/unsafe.
I've just repaired my trusty Quad 34 pre amp and fitted a new power socket and power switch as both were knackered. I've soldered as neatly as I can and the amplifier now works fine. Just wondered if you could have a look and advise if my soldering is ok? Thanks.
Old 25th February 2009, 10:30 PM   #2
jaycee is offline jaycee  United Kingdom
Very neat job. Well done
Old 25th February 2009, 10:39 PM   #3
From that shot, it looks OK. A higher-quality close-up may or may not reveal any errors.
Good job leaving the insulation close. You can clean off the flux... or just leave it. Wouldn't be too big a deal to leave it on with most types of rosin-core solder.
Old 26th February 2009, 11:40 AM   #4
Thanks, Have another pic!
Old 26th February 2009, 01:48 PM   #5
another pics
Old 26th February 2009, 03:22 PM   #6
bear's Avatar
Probably ok...
The last pic shows the green wire... may or may not be ok, can't see really.
It is possible to make a reasonably good looking joint like the one you have where the wire is really only held in by the flux/rosin.
To take an extreme closeup, take a magnifying glass, place on the lens of the camera, press just enough to enable to focus feature, and then get as close as you can and still stay in focus, click...
depending on what is on the other side of that lug, you may or may not have enough solder there... another consideration.
Another thing, when making connections of this type it is good idea to mechanically bend the wire around the lug (after going through the hole), this way there is a larger surface area for the solder, and a mechanical connection to the lug - this makes a stronger joint, and has less chance of stress cracking in time...
The military does things this way for that reason.
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
soldering help! speedboy Parts 3 14th November 2008 04:04 PM
soldering DIY IC rnzr Everything Else 2 24th March 2005 04:00 PM
more soldering help please theChris Equipment & Tools 22 5th June 2003 04:07 PM
On Soldering vpharris Equipment & Tools 9 23rd April 2003 06:14 PM
Soldering to-363 PCP Solid State 1 18th January 2003 12:30 PM
Page generated in 0.10307 seconds (71.69% PHP - 28.31% MySQL) with 11 queries
