Help Need To Repair Marantz Pm 94 Class A Amp
Old 27th February 2009, 03:16 PM   #11
c2cthomas is offline c2cthomas  United States
c2cthomas's Avatar
Originally posted by EDDELARUE
It was the same mode as Yamaha M-85 ?
I have no idea if it was the same mode as Yamaha - but you have made me curious so I will see what I can find out. Most likely won't have much luck tho
Perhaps there is someone around that has worked on both amps that might be able to inform us with first hand knowledge.
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 27th February 2009, 03:26 PM   #12
c2cthomas's Avatar
Similar
http://www2.yamaha.co.jp/manual/pdf/.../SepA/M-85.pdf
Old 27th February 2009, 08:44 PM   #13
EDDELARUE is offline EDDELARUE  Brazil
EDDELARUE's Avatar
Send a message via MSN to EDDELARUE Help Need To Repair Marantz Pm 94 Class A Amp
Yamaha M-85 is a class G amplifier type. It has two power supplies for output stage and it has one switch to select "class A" operation too. The M-85 model belongs to "Natural Sound" line amplifiers from that manufacturer.
Old 27th February 2009, 09:09 PM   #14
EDDELARUE's Avatar
Look this
Old 27th February 2009, 09:11 PM   #15
EDDELARUE's Avatar
Look this,
Old 28th February 2009, 12:00 PM   #16
EDDELARUE's Avatar
Ops! Im sorry for empty replies...
Look this,
Yamaha M-60
http://www.hifiengine.com/manuals/yamaha/m-60.shtml
This schematic is very similar to M-85. It is class G too.
Marantz PM94
http://www.hifiengine.com/manuals/marantz/pm-94.shtml
Old 28th February 2009, 05:33 PM   #17
data is offline data  Australia
Bulging or leaking caps? replace them for sure...
I have a PM64ll from the same series, personally I'm going to re-cap this whole amp.
20 years old and producing the levels of heat that they do, makes me think that a Re-cap is in order. This one of mine has DC passing through from the phono stage, so that's maybe a bad cap or caps.
The PM94 is a beauty, should serve you well once the repair is done
Old 17th June 2009, 04:51 PM   #18
Ganx is offline Ganx  South Africa
Hiya Seafire,
Did you get results on that PM94??
Just curious as just done one - they are a whole lot of amp!!
Old 23rd November 2009, 09:47 AM   #19
reddish75 is offline reddish75  United Kingdom
hi, i have one of these amps with a burnt resistor on the underside of it, near the front on the middle pcb, there is also a cut in the track in the same area, does yours have this? if so could you tell me the resistor value?
regards
chris
Help Need To Repair Marantz Pm 94 Class A AmpHide this!Advertise here!
Marantz SR-50 receiver repair Stuey Solid State 18 10th October 2009 06:08 PM
Marantz PM-17 repair hirafu_boarder Solid State 0 20th July 2007 02:25 PM
Marantz DR6000 repair logomomo Digital Source 0 6th March 2006 05:19 PM
Marantz receiver repair SoundQuest Parts 0 4th June 2004 06:24 AM
Copyright ©1999-2017 diyAudio
