diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Will this balanced PSU work as intended? (http://www.diyaudio.com/forums/solid-state/139204-balanced-psu-intended.html)
Will 24th February 2009 05:49 AM
2 Attachment(s)
I'm having 2 of these stepdown transformers (240V to 120V) that do not have center tap, but I would like to derive balanced voltage output.
Will this arrangement work ? It will be used for a linestage pre-amp.
Thanks.
CBS240 24th February 2009 05:44 PM
Hi Will
How many volts do you need for a SS line stage pre-amp?:confused:
Much less than 170, I presume.
If you are using those high voltage empty glass thingies:D, you're in the wrong forum. (not that there is anything wrong with 'em):)
You need a resistor voltage divider to set the floating GND potential on the caps halfway between +/-. Also, You could build an active floating GND. (current amplifier for the floating GND reference)
jan.didden 24th February 2009 07:06 PM
Re: Will this balanced PSU work as intended?
Thanks.
Will,
You say you have two xformers. Why not put the primaries in series and use each secondary full wave rectification? You have then two voltages of about 40V that you can put in series with the connection point to ground, that are much lower and closer to what you will need. Or you can put the secondaries in series and use half-wave rectification.
Jan Didden
Will 24th February 2009 09:37 PM
Originally posted by CBS240
Hi Will
Yes it's used for a tube buffer linestage ala Joe Rasmussen's SLCF BUT the issue concern here is related to sand diodes
:D
What values do you recommend for the resistor values to be at?
Cheers.
Will 24th February 2009 09:41 PM
Re: Re: Will this balanced PSU work as intended?
Originally posted by janneman
Will,
Jan Didden
Jan,
If I have 2 of them in primary series, that should mean that both 240V primaries will receive 120V each, and hence each of the secondary will be at 60V, and with 2 transformers of secondary in series then I should have 60-0-60VAC right?
Cheers.
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
