When i posted a message earlier i got this thought in my mind..
Often newbies like me have a lot of trouble with starting off with understanding the fundas of SS amp design. why dont we start a thread where the more experienced members handhold the newbies till they walk on their own. its easy to simulate and observe a design given in a textbook but what if someone wanted to build their own. agreed most authors give their explanations abt the function of components in their design. But can we start a thread where a topology is given and u give directions on how to design ? |
#2 |
SS tutorials abound.
Try ESP and Pass sites as starters. |
#3 |
@andrew
thank you.. |
#4 |
Hi all!!
been coming here for years but never registered.Nice forum.Thats all changed now as my sister donated a marantz pm94 class A (semi) amp.However it switches on but no sound so i opened it up and found a popped mosfet Help!! what i know about electronics is dangerous.where do i post my questions and get some answers to repair this amp
#5 |
expert in tautology
First do a search for the thing you are interested in, in this case a Marantz Xxxx, and see if anyone said anything before about it. Might want to search for the exact term, otherwise all things Marantz will spring up... Then put up a new post (top of the list for a given category, and be sure to click the box "I have searched" and type in what you want to ask about!
Trouble shooting is a different art then engineering/design. You can actually troubleshoot many circuits without actually knowing that much about how they were designed, or the details of how any given stage actually works! Krish, For text books, there are many but Horowitz and Hill: The Art of Electronics has the advantage of being writen in an easy to read style, which is very useful if you want to read about something without doing mathematical analysis in order to understand the idea. The online sites will help too. There are many discussions on here where the way that a given circuit works, however they generally assume that you already know something about things like how a transistor works and how it is biased for example... but you can pick up this sort of general information from books and online sites. Youtoobe also has some tutorials, fwiw. _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#6 |
@bear
i have read TAoE and i agree that it is pretty good for someone like me.. can u list out a couple of sites which might be of help?? i do refer to ESP regularly and after andrew's suggestion i have started going thru pass site also.. |
#7 | |
49 - for the 17th time
http://www.bcae1.com/ http://www.epemag.wimborne.co.uk/solderfaq.htm#howto http://myweb.tiscali.co.uk/nuukspot/...rted.html#top1 http://tangentsoft.net/elec/movies/ http://www.allaboutcircuits.com/ There are many things to learn before you become "seasoned". So - you start at the beginning and start with a simple project that will develop those skills and firm up the knowledge. A bit similar to taking a "lab" class in school. You get a bit of "hands on" experience and the reward of having built something. Then you advance to the next stage - and so on. It will take time - but all things worth while usually do. Take the time to enjoy the journey and the new friends you will meet! 10 or 20 years from now you will spend fond moments recalling your first amplifier build and enjoy sharing your knowledge and experience with a newcomer that is just starting out on their journey into this hobby. Oh - BTW - you should be prepared to make some mistakes - we all do!!
DIY audio can be expensive – but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
#8 |
thank you thomas...
i m very prepared to burn my eyebrows.. thanks for the links theory is one thing but a theoritical knowledge with hands on is a killer combination ...
#9 | |
| tutorial software | ectobia | Tubes / Valves | 1 | 17th October 2007 02:19 AM |
| Looking for a tutorial? | Carcano | Chip Amps | 6 | 3rd October 2006 05:50 AM |
| Definitive Tutorial For Newbies? | Michael Rothacher | Analogue Source | 1 | 16th March 2003 10:38 AM |
