Why do opamps "rail" ? - Page 2 - diyAudio
Old 23rd February 2009, 06:45 PM   #11
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Default Re: Re: Most of the time...
Originally posted by wg_ski
That's not the op-amps fault.
Nope, and that was my point. I guess I should have been more clear. Most times I've had an op-amp go to one rail, it's because of a wiring or design mistake. Rarely have I had a bad part. Understand how op-amps work and circuit faults can be readily diagnosed.
Scott
Old 23rd February 2009, 06:53 PM   #12
wg_ski is offline wg_ski  United States
Yeah - I just assumed it was the usual noob mistake of why the output is sitting at -14 when both inputs are grounded.
Old 23rd February 2009, 07:21 PM   #13
syn08 is offline syn08  Canada
Originally posted by AndrewT
why do some invert the output when driven hard?
Simplified, because an inverting gain stage may (depending on the toplogy) become non-inverting when the active device(s) saturate. Therefore, negative feedback becomes positive feedback - and the output latches.
Old 23rd February 2009, 07:42 PM   #14
Michael Chua's Avatar
I had TL074 went to the rails before. It was wired as Unity Gain Buffers for a distribution amp as in one of their Application Notes. Initially on power up, no problems. Left it on overnight. Next morning, output was at one of the rails. Apparently, the output DC offset crept towards the rail as the opamp temperature increases.
ampslab.com/blog
Old 23rd February 2009, 07:59 PM   #15
megajocke's Avatar
If one AC-couples the input without a DC-bias setting resistor after it something like that could happen... Input bias current of the opamp is pretty low so it might take a while though
Old 23rd February 2009, 08:09 PM   #16
Pardon my ignorance, but what exactly does a DC bias setting resistor do?
Old 23rd February 2009, 09:05 PM   #17
jan.didden's Avatar
Simple: they rail because the differential input voltage times the gain is higher that the supply voltage.
Now, the reason for that may be another story...
Nice try Jack!
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 23rd February 2009, 10:09 PM   #18
Nice try Jack!
Jan Didden
Jan,
Your response was what I was trying to say...but you said it way better.
Thanks,
Scott
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Rail Switching vs. "predictive" rail switching rtarbell Solid State 5 4th March 2007 11:26 PM
Switching amp and "ground rail" rtarbell Solid State 3 6th July 2006 04:49 PM
"reduce rail voltage 20% > pick up on sonics" rick57 Solid State 7 13th April 2006 01:45 AM
Mancini "opamps for everyone" PDF jackinnj Solid State 6 4th March 2004 10:12 PM
Copyright ©1999-2017 diyAudio
