About power amp step response etc. :-)
Old 23rd February 2009, 09:31 PM   #21
PMA is offline PMA  Europe
PMA's Avatar
It is also the feedback stability that counts, is not it?
This amp has no global feedback, and Zout is about 0.03 ohm.
The load may seem impossible, but some of the full range electrostats have quite pure capacitance up to some 10uF.
Old 23rd February 2009, 09:45 PM   #22
syn08 is offline syn08  Canada
A 10uF load would require much more current (hence more output devices) or a larger coil (hence limited rise/fall times). As I do not plan to sell my amps, I design them for regular speakers, 2 ohm minimum impedance including the phase shift. That is, the protection kicks in for loads around 1.8 ohm. That's where the 24A number comes from and so does the number of output devices (3). But then 50nS rise/fall time is a clear overkill so if I would have to feed electrostatics of the worse kind I would simply rise the output coil value to maybe 2uH. This and the input filter will provide enough room to feed those crazy loads, up to the nominal power.
About power amp step response etc. :-)Hide this!Advertise here!
where to buy step-up power supply Ipanema Car Audio 4 12th June 2009 01:53 AM
Newby Q: difference btwn Step and Impulse response brucemck2 Multi-Way 3 22nd May 2008 07:17 PM
"Distorted" step response tipo1000 Multi-Way 19 14th September 2007 05:08 PM
Baffle Step Response in WWTM ? Eton Multi-Way 5 5th November 2006 06:36 PM
How To Read Martin King's Step Response Graph? kelticwizard Multi-Way 10 3rd March 2006 01:41 AM
