diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Preamp for Power Follower 99 (http://www.diyaudio.com/forums/solid-state/139042-preamp-power-follower-99-a.html)
Ant1Xr1st 21st February 2009 05:28 PM
I'm have finished building the "Power Follower 99" (5Abias , 81v, 100Wrms) ;)
Now i'm looking for trasistor or tube (maybe) "voltage preamp" for it (or how it's called on eng.)
*Sorry 4 my eng. Tnx.
PMA 21st February 2009 07:44 PM
I wonder what kind of cooling system you have used. Heat pipe?
Luke 21st February 2009 08:08 PM
Thats dissipating 800watts per channel:bigeyes:
How many outputs and can we see pics of this amp and maybe a schematic:-)
Ant1Xr1st 21st February 2009 08:59 PM
Water cooling system, Thermaltake waterblocks & pump and ProModz 360x120mm radiator :D
450W off dessipating power :D
2 Attachment(s)
Originally posted by Luke
voltage seems kinda high for 100 W, is it +/- 40V, or are you dissipating 800watts per channel:bigeyes:
How many outputs and can we see pics of this amp:-)
This scheme has "virtual ground operation" and uses +81v input, but in rezult, it have +-40.5
If there is a 800watt of power, mofets will burn :hot:
Ant1Xr1st 22nd February 2009 11:19 PM
2 Attachment(s)
Shematic is in attachment. Case type - TO247. Every mosfet's gate have a feerite "bead"
What with the preamp scheme? Could you give me some?
GoranB 4th March 2010 09:21 AM
maybe you already built an preamp for power follower till now, im useing andrea's pre amp with tubes. It sounds great on midrange and high, bass is not controled well. I can sugest you to connect PF 99 to direct source, you'll get the best results that way
GoranB 9th March 2010 06:28 PM
Maybe here you can find some interesting sschematics for your power follower (tube designs)
HeadWize - Project: Top-Level OTL Tube Headphone Amplifier by Andrea Ciuffoli
Resources saved on this page: MySQL 18.75%
