tarmac ripper
Folks,
I need to build a pair of Jungs regulator (positive V and negative V) for my DAC but I am having problems with the spice simulations I am running before the soldering the proto. I will use OPA37 and not LT1115 (I had no model for the BB opamp). The positive reg seems to be OK: R3 is a 1K pot and I can set the output voltage down to +12V (larger value will allow to go down to the minimum possible set by the zener). R7 represent the load. pos reg The negative reg doesn't work. SOOB. I am quite a newbie with solid state. I can't find out whats wrong there. neg reg Thanks Gianluca |
#2 |
hello.
perhaps try r2-r3 connect to the negative rails (and not to ground). greetings.............. |
#3 |
tarmac ripper
Hum ... no. That would not work. The circuit seems to regulate with no problem if the zener is connected (via the R4 resistor) before the mosfet drain (ie at the raw supply).
Thanks Gianluca |
#4 |
hello.
perhaps reverse the polarity of the signalgenerator....... and/or sine(-35 1 10). greetings............... |
#5 |
connect a 10k resistor between S and D of IRF
| yes, another jung regulator, i know | geekysuavo | Power Supplies | 8 | 25th September 2009 12:29 PM |
| About Jung super regulator | MaxS | Power Supplies | 103 | 6th August 2009 07:50 PM |
| WTB: Jung Super Regulator PCB's | vadimgal | Swap Meet | 4 | 29th May 2005 06:04 PM |
| Page generated in 0.07530 seconds (75.48% PHP - 24.52% MySQL) with 10 queries |
