I've poked around the site looking for schematics with no luck but here's my issue ... and i could certainly use some help
The fuse is blown on the left channel. When i swapped that fuse with the good right channel fuse, the left channel has a hum without any input signal. With an input signal the hum stays the same, and there is no audio at any volume level (beyond the hum). One interesting thing that i noticed when i cracked open the amp...was that the circuit boards for the left and right are not only different, but the circuits differ also. This is a unit i purchased in 1980...and has been in a box for most of the last 20 years. So any thoughts? i had read that it uses an lm391 op amp. Do those suckers go bad...and if so, are they still available anywhere? |
#2 |
guess this kinda got lost in the shuffle....
#3 |
frugal-phile(tm)
this will help
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
frugal-phile(tm)
#5 |
awesome thanx!....
#6 |
Planet10....
I was printing out those schematics you so nicely found for me when i thought "hey i should probably try and get the right channel also...while i'm at it" so... would you mind terrribly postinig the right side also... Thanx much :-) |
#7 | |
frugal-phile(tm)
dave
#8 |
maybe ultimately that is my problem... :-(
the circuit boards are different...and the circuits on them are also different i'll have to see if i can document the differences... but there are different values on some resistors, and there are at least 3 more components on the left side (caps and chokes) |
#9 |
Hi objective1,
The L & R channels should be the same. The extra components you see may simply be some "housekeeping" stuff. Why not look at National's site and see what they have on the LM391-100. I think that might be the only one in that series left. Anyway, the application notes may give you some good hints. I have often seen commercial equipment be almost identical to the application suggested circuit. Look here for details, it seems to be discontinued, but distributors may still have stock. Buy a couple while you are at it. I see that both Newark and Digikey indicate 0 stock on these. Mouser doesn't carry National. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#10 | |
frugal-phile(tm)
Here it is.. the one i 1st posted said rev 2, and is dated 11-6-84. This one is not clear enuff to pull a date. Both the ones i owned would have pre-dated 1984 dave
| FS Amber Series 70 amplifier - make offer | evinrude | Swap Meet | 1 | 24th October 2008 01:57 AM |
| Amber Series 70 | planet10 | Solid State | 10 | 19th October 2008 11:27 PM |
| Amber 3501 | Vidalgo | Everything Else | 9 | 19th October 2008 11:27 PM |
| Amber 17 Pre-amp?? any info | Zero Cool | Solid State | 2 | 24th December 2007 11:46 PM |
| Page generated in 0.11467 seconds (82.25% PHP - 17.75% MySQL) with 11 queries |
