Old 22nd February 2009, 12:55 AM   #11
Default check these...
http://www.diyaudio.com/forums/show...&threadid=42259
http://www.dddac.de/op06.htm
moray james
Old 22nd February 2009, 11:17 PM   #12
amz-fx is offline amz-fx  United States
Dano,
I built a small amp similar to this one and it worked just fine on 9v to 12v, but not terribly loud.
I would suggest that R1 be changed 100k or even 1M. Also the C1 input capacitor needs to be turned around so the plus side is to the mosfet.
When used with 9v, mine did not get hot enough that a heat sink was even necessary, though I did not drive it hard for long periods.
regards, Jack
http://www.muzique.com/
Old 22nd February 2009, 11:23 PM   #13
Fuling is offline Fuling  Sweden
I´ve built a couple of amps quite similar to the one in post 3 and with the right speakers this topology has some nice features.
(fullrange drivers sometimes sounds better mated with high Zout amps).
Driving the Mosfets input capacitance requires and active preamp though.
Old 23rd February 2009, 02:29 PM   #14
djk is offline djk
djk's Avatar
"Any ideas on what I've done wrong?"
You don't have a schematic that's useable.
130mA?
If R2 was an active current source, then 130mA of bias would be 0.092 mA into an 8 ohm speaker. (I^2)R=0.067W
67milliwatts.
Throw away this schematic.
Read this:
http://www.passdiy.com/pdf/zenamp.pdf
Circuit board here:
http://www.audioxpress.com/bksprods/...ts/pcbp-11.htm
Candidates for the Darwin Award should not read this author.
Old 23rd February 2009, 03:21 PM   #15
dano12 is offline dano12  United States
Thanks guys for all the advice.
Turned out that I hadn't properly grounded the source of the FET (doh!). After doing that it fires up fine.
I'm running it at 18 volts, the FET barely gets warm but the 50 ohm resistor get's very hot. I'll take the recommendation and remount it on a heat sink.
Jack, thanks for the ideas. I actually used your excellent MOSFET boost as a preamp.
I'll reverse the cap and do some more tinkering tonight.
Old 23rd February 2009, 03:38 PM   #16
If you are running it at 18v you could replace that 50 ohm
resistor with a 12v turn signal light bulb.
What are you using as a input source? If your input source
is a something like a cd or sound card you might get better
results with these componints using them in a source follower.
Old 23rd February 2009, 11:28 PM   #17
As far as I'm concerned, mission accomplished with this one. I fashioned a hillbilly heatsink for the power resistor, stuck a single transistor pre-amp in front of it, stuck it in a computer CDROM cage and called it a day.
It makes a nice little guitar amp, drives an 8 ohm cab very well.
I think now I'll move on to some of the better suggestions posted here.
Thanks again for the pointers!
Old 24th February 2009, 12:18 AM   #18
djk is offline djk
djk's Avatar
If you replace the resistor with an LM317 regulator it will double the efficiency of the amplifier, and double the output power, and the regulator will probably cost less than the resistor.
Old 24th February 2009, 12:19 AM   #19
mosfets is offline mosfets  Canada
Originally posted by dano12
... I fashioned a hillbilly heatsink for the power resistor, stuck a single transistor pre-amp in front of it, stuck it in a computer CDROM cage and called it a day
That is the coolest piece of crXp I've ever seen on DIY! I want one just like it STAT.
Old 24th February 2009, 01:35 PM   #20
PMA is offline PMA  Europe
PMA's Avatar
http://sound.westhost.com/project83.htm
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
He helps with amplifier " Lineal Power" Model 652IQ diegodgo Car Audio 1 28th October 2006 09:05 PM
LM3886 GC - "Simplest Ever Amplifier Bridging" jweber Chip Amps 20 18th June 2006 03:55 AM
Newbie wants to build a "GainClone-Like" 5.1 Channel Battery Powered Amplifier captain Chip Amps 7 15th October 2004 01:35 PM
Page generated in 0.11871 seconds (77.67% PHP - 22.33% MySQL) with 11 queries
