mosfets said:
That is the coolest piece of crXp I've ever seen on DIY! I want one just like it STAT.
I think I'll call it the "Pinnacle" or some other superlative and start selling them on ebay for 1000 bucks.
dano12 said:As far as I'm concerned, mission accomplished with this one. I fashioned a hillbilly heatsink for the power resistor, stuck a single transistor pre-amp in front of it, stuck it in a computer CDROM cage and called it a day.
It makes a nice little guitar amp, drives an 8 ohm cab very well.
I think now I'll move on to some of the better suggestions posted here.
Thanks again for the pointers!
I like it aesthetically too. Very MECHANO! Must be sounding direct and ''warm''?
FWIW, here is the corrected schematic that I ended up with:
dano12 said:FWIW, here is the corrected schematic that I ended up with:
I think Dano is an artist.
Perhaps like a movie prop? ...good times.
Out of curiosity, what's the purpose of the 470uF cap with both ends connected to ground?
EDIT: Ooops, dupe of Bonsai's post.
Is 220 µF for C2 a typo? That would give f-3dB at 90 Hz with an 8 Ohm load = no bass.dano12 said:An externally hosted image should be here but it was not working when we last tested it.
tenetA
I see you also play with this simplest curcuit. Many people are laughing when they see this amp, but I built in this way the best sounding amp ever. I made about 20 amps ( tube SE PP, tube OTL, MOSFET SE PP, hybrid ) but no one sound so good like this. But there is alway a big BUT - it was powered from batery and the usable output was 0,5 - 1 W ( 0,4 % THD ).
Two car bateries in livingroom is a problem ...
RD
RD
Re: tenetA
Acid-resistant trays below them would be an advantage in case they get leaky.dusr_123 said:Two car bateries in livingroom is a problem ...
- ISO "Simplest" possible amplifier
