Old 12th February 2009, 09:57 AM   #1
destroyer X's Avatar
Default Is this FET good to use into audio amplifiers?
If no good, why?
Please, inform the complementary, i have many FETs in my home and i do not know if i can match them to work as complementary.
What is the main characteristics i should observe into the datasheet to decide if they can work together? (studing N type and P type).
Is this mismatch related drain to source resistance something important to worry about?... some of them, for instance, having 0,47 ohms and others having even lower...or higher resistance.
Because of Dudainc kindness and also Anonimous kindness, now a days i have hundreds of power FETs in my home... also BGT power units and drivers.
Thank you,
regards,
Carlos
Old 12th February 2009, 10:02 AM   #2
Default Can i use this one together the previous one?
I have many units... would be very interesting.
regards,
Carlos
Old 12th February 2009, 10:44 AM   #3
syn08 is offline syn08  Canada
These are decent vertical power mosfets. Although originally intended for switching, they will do a fair job in audio amps. The closest equivalents I can think of are IRF240/IRF9240
Old 12th February 2009, 11:22 AM   #4
Nrik is offline Nrik  Denmark
Carlos
I cannot imagine that I am gonna say this to YOU, but......Try it!
Feedback should take care of whatever non-linearities there might be. Try them in maybe in these:
http://www.adam.com.au/cgpap/QuasiWeb/index.htm
...and tell us about it.
Henrik
Old 12th February 2009, 11:26 AM   #5
Grollins uses exactly this one and its P-channel in his 25W class A amp here:
The GR-25
...even without feedback! So these must be very good for audio.
Old 12th February 2009, 11:28 AM   #6
sajti is offline sajti  Hungary
Can be useful in any N channel MOSFET amplifier.
Sajti
Ps.: Did You clean up the Fairchild warehouse?????
Old 12th February 2009, 12:06 PM   #7
Default Thank you Henrik, Sinesthesia and Satji
Yep.... a good idea is to try....but i would like to learn how to make a good choice of models searching for matched pair.
Thank you folks,
regards,
Carlos
Old 12th February 2009, 01:46 PM   #8
megajocke's Avatar
I'd try to find something that has similar slope in the Vgs-Id characteristic (transconductance).
Old 12th February 2009, 09:16 PM   #9
Default Re: Is this FET good to use into audio amplifiers?
Originally posted by destroyer X
Please, inform the complementary...
To the extent that average vertical MOSFETs have complements, try the FQA12P20. Works nicely.
Grey
Old 13th February 2009, 10:17 AM   #10
Default Thank you....now i have more informations about
and i can try something.
Carlos
The good, the bad, and the ugly OTL amplifiers Original Burnedfingers Tubes / Valves 46 9th November 2006 06:27 AM
IRFP90N20D Monster-Any good for Amplifiers? zox2003 Solid State 14 11th March 2005 02:17 PM
schematics for amplifiers, found good site NB23 Car Audio 0 12th June 2004 10:42 PM
pro amplifiers vs. home audio amplifiers bonsai171 Solid State 26 25th February 2004 08:24 PM
IC audio amplifiers jteef Solid State 8 21st July 2001 03:14 PM
Page generated in 0.10400 seconds (75.30% PHP - 24.70% MySQL) with 11 queries
