Old 11th February 2009, 06:22 PM   #1
Send a message via AIM to zerohead_ak47 Send a message via MSN to zerohead_ak47
Default my hi-end amplifier
i have made calculations but i didnt try the amp yet..what is your idea about this amp?
thanks
Old 11th February 2009, 06:39 PM   #2
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
The VAS will only swing as high as the cascode voltage, about +/-39V. Also you need to put a reverse bias diode from C to E across the cascode transistors to prevent them from reverse biasing during clipping. If you use a cascode VAS with a voltage following output stage, you need boosted rails for the VAS to drive the output to full swing.
All the trouble I've ever been in started out as fun......
Old 11th February 2009, 07:46 PM   #3
hi cbs240
i put 470r instead of 5k6 thd became lower (at high power )
can you sign the position of diodes?
i dont know where to put them
thanx
Old 11th February 2009, 09:05 PM   #4
wg_ski is offline wg_ski  United States
Originally posted by zerohead_ak47
hi cbs240
thanx
It's more common to use a 3 to 5 volt zener diode in place of the 470R/5k6 to bias a cascode VAS.
As for which direction to put Baker clamps - in normal operation reverse bias. Point it "uphill".
Old 11th February 2009, 09:18 PM   #5
Default edit
thanks all
new schema
Old 12th February 2009, 12:40 AM   #6
CBS240's Avatar
hi cbs240
Yea, when you aren't cutting off the peaks of the signal, harmonic distortion decreases.
But now, the green LED's will produce around 4 - 6V. The maximum VAS voltage swing is about 55V. The problem is, you still can't get the output up to full swing, rail to rail. If you have no voltage gain in the output stage, nothing wrong with that, but you need to have boosted voltage rails for the cascode VAS. The good news is that the boosted rails require realitivily little current and can be easily regulated for better supply rejecton.
On the flip side, you might could use a small bootstrap from the output to supply the voltage boost to the regulators to raise the rails when the output swing is full.
If you do something like this, you might want to replace the 12K resistor with a current source.
Old 12th February 2009, 04:12 AM   #7
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Whatz so high end in this amplifier?
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 12th February 2009, 05:22 AM   #8
ostripper's Avatar
My , My... this does look familiar.
Another Holman topology amp.. they do work very good,
better than a blameless. You can place a 200R trimmer/1k3
in place of the top 1K5 to get perfect LPT Ic.
They beat me to it , but a standard "blameless" led or
2 diode CCS is the "way" (80db PSRR -1k).
As far a being a high class amp, it can be as good as
any fully balanced VAS topology. I have one built just like
it (fa3) , and it sounds so good , I'm basing my next 2 amp's
on it (6 device triple OPS BJT and MOSFET).
The only issue this particular design has is that a high
gain input pair (LPT) must be chosen (zetex 696 or high
gain group ksc1845/KSA992) your 970's with no degen might just
give you 55db OLG max..
Attached is a similar amp , "steal" any idea off of it
it does work ,by the way.. very reliable.
OS
Old 16th February 2009, 03:44 PM   #9
just try it..it sounds wonderful
Old 16th February 2009, 04:53 PM   #10
LATFET VERSION
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.11081 seconds (81.88% PHP - 18.12% MySQL) with 11 queries
