More power with less capacitance. Why?
Old 8th February 2009, 03:20 PM   #1
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Question More power with less capacitance. Why?
Right!
So, my Peavey Electrolytic modification was a success and, I have now moved on to some of my Crown Amplifiers.
Looking at the Schematic the amplifiers offer Capacitors with the following ratings:
Macrotech 600 = 7800 MFD
Macrotech 1200 = 10000 MFD
Macrotech 2400 = 6300 MFD
I am going to upgrade the MA 2400's with a pair (two for each amplifier, six in total) of these in the near future.
Does anyone know why Crown would offer 6300 MFD Capacitors in the MA 2400 while, offering more capacitance in their 1200 & 600 models?
Cheers!
OMNIFEX
Old 8th February 2009, 03:34 PM   #2
possibly because the high voltage caps cost too much to supply the correct/adequate capacitance.
I suggest you buy 8 (+-50mF/channel) if they can fit the space available.
regards Andrew T.
Old 8th February 2009, 04:03 PM   #3
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Could be the supply is designed to sag under heavy load to save the inadequate output stage from failure. Just a thought...
Old 8th February 2009, 04:58 PM   #4
east electronics is offline east electronics  Greece
east electronics's Avatar
Default very very possible
especially if we think that some of these models work the otherway arround like all collectors grounded ....
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 8th February 2009, 10:51 PM   #5
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
I agree with Andrew on the cost issue, but to my understanding both output power and energy stored in a capacitor are proportional to the square of supply voltage, so there is basically no reason why higher power amp should have more capacitance in the supply.
Old 9th February 2009, 05:21 AM   #6
djk is offline djk
djk's Avatar
"I suggest you buy 8 (+-50mF/channel) if they can fit the space available."
There is only one cap per channel, they're bridge amps.
If we did take your advice we would see rectifier failure.
6800F gives 90% regulation on 60hz, 8200F on 50hz (4R loads).
The Crown Macro Reference, a 1500W per channel amplifier that was highly acclaimed by Stereophile magazine (for its sound quality), limps by with only a pair of 6300F cans.
http://www.crownaudio.com/pdf/legacy/mrschematics.pdf
Candidates for the Darwin Award should not read this author.
Old 9th February 2009, 10:14 AM   #7
Are you sure?
Is soft start fitted to the transformer?
Is slow charge fitted after the secondary?
These two remedies should already be there. If not then fit them.
regards Andrew T.
Old 9th February 2009, 02:38 PM   #8
djk is offline djk
djk's Avatar
"Are you sure?"
Yes, see the schematics.
The schematic I showed for the Macro reference does have inrush limiting, the Macrotech/Microtech/Powertech/Powerbase 600/1200/2400 do not.
http://www.crownaudio.com/pdf/legacy...5-4%20revf.pdf
"Is soft start fitted to the transformer?"
No.
"Is slow charge fitted after the secondary?"
No
"These two remedies should already be there. If not then fit them."
A big job, and needed if you re-design the supply as you suggested. I suggest leaving them alone, they work OK as is. The only thing I would add would be bypass caps to the main filter caps, and film bypass the electrolytic coupling caps, etc.
(or buy a Crest)
Old 9th February 2009, 03:28 PM   #9
OMNIFEX's Avatar
So I take it, having 6300 MFD in the MA 2400 is a mystery.
Nevertheless, should I upgrade the bridging rectifiers when I begin this project?
They are 35 A 200 volts. One for each channel.
Cheers!
OMNIFEX
Old 9th February 2009, 04:16 PM   #10
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
the rectifier failure problem is not from start-up. the problem is the repetitive high current spikes during operation that keeps the caps charged. these high currents are somewhat mitigated by the fact that as the rated voltage of an electrolytic is increased, it's ESR rises as well (it's partly due to the fact that the oxide layer on the plates is thicker and the conductive portion is thinner)
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
More power with less capacitance. Why?Hide this!Advertise here!
reservoir capacitance for power output lt cdr data Solid State 0 7th July 2007 02:14 PM
How much capacitance in a power supply TugaTweaker Tubes / Valves 2 29th January 2006 05:40 PM
Power supply capacitance winslow Pass Labs 5 13th August 2005 02:54 AM
Too much capacitance in power supply? G Tubes / Valves 12 15th February 2003 02:08 AM
Power supply and capacitance.... Lisandro_P Solid State 10 8th November 2001 04:15 AM
Copyright ©1999-2017 diyAudio
