#21 | ||
zaudio |
#22 |
Electrons are yellow and more is better!
Notice that Jan's Lynx amp is the same as you have built but with a upgraded design.
http://www.audio-circuit.dk/index.ph...ects&Itemid=60 Notice that diyaudio.com doesn't like his URL
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#23 | |
#24 |
Unfortunately I finished with this , cos nothing' s help.
I am going to make a sand with hammer.
zaudio |
#25 | ||
NOW THIS IS WORKING, YES, YES, YES!!!! SORRY TO BE NERVOUS IN THE PREVIOUS POST, SO WHAT HAPPENED: FIRST I TRIED WITHOUT THAT CAP C10, WHEN I TURN ON THE AMP, I NOTICED A SMOKE COMING OUT FROM THE R25+L1(OUTPUT HF SUPRESSOR) AND TURNED OFF. AFTER I TRIED WITH HIGHER VALUES OF THE C10 TILL 1000 PF BUT NOTHING CHANGED!!! FEW MINUTES AGO, A BIT MORE RELAXED COME BACK TO THE AMP AND PUT 18 PF FOR THE C10 AND AMP IS PLAYING MUSIC AT ANY POSITION OF THE TRIM. POT FOR BIASING!!!!!!!! NOW HOW CAN I BE SURE THAT 18 PF IS THE RIGHT VALUE FOR MY AMP?????? AND HOW TO MEASURE IF , PERHAPS SOME OSCILLATIONS ARE ABOVE THE AUDIBLE FREQ. ABOVE 20 KHz?????? MY BIGGEST THANKS TO MEGAJOCKE AND WG_SKI, YOU HELPED ME, AND WILL WAIT FOR YOU IF SOMETHING I CAN CHANGE IN ORDER TO GET THE MAXIMUM FROM THIS AMPLIFIER!
zaudio |
#26 |
If it were still oscillating, you'd have either distortion or smoke. The fact that you have neither suggests it's stable now.
To get the max out of the amp, go as low as you can on that cap without peaking in the closed loop response. If you can't measure that, use your ears. Above-band peaking will cause it to sound very "detailed" or "bright" initially, but cause fatigue from extended listening. My guesses say this will happen when you get down around 6-8pF. It may start oscillating before than anyway. |
#27 | |
I would like first to thank You for Your help. No, the sound now is clear and detailed, when the amp. was oscillating, i can hear "bird song when the drums hit" I will stay at this value of c10=18pf. Now I must to check the bias of the power tr. . Also I would try with changing the TL 071 with NE5534, to see if the sound is better? Do you think that NE5534 will work now ?
zaudio |
#28 |
"Do you think that NE5534 will work now ?"
Sure, as long as you tack the compensation cap across the correct pins on the back side of the board. See the 5534 data sheet for the suggested values.
Candidates for the Darwin Award should not read this author. |
#29 |
All was my mistake!
The c10 was "681" cap that means 680 pf. I solder 60 pf in place of c10 cos don't have 68pf, even amp was working with 18pf, so nothing's wrong with this scheme.
zaudio |
#30 | |
And "680" could mean either 680pF or 68, further adding to the confusion. If you're ever in the market for a new DMM, get one with a capacitance function. |
| Oscillating P3A | sobazz | Solid State | 8 | 28th July 2003 05:21 PM |
| Oscillating amp. | DaViruz | Solid State | 23 | 5th December 2002 01:50 PM |
